Running multi themes
This is a discussion on Running multi themes within the Gingerbread Themes forums, part of the Gingerbread Development and Hacking category; I am on apex 2.0 beta .591 deodoxed running watermark and stealth themes, should I expect problems using multi themes on top of each other. ...
Thread: Running multi themes
    patrick72's Avatar
    22485
    55
    I am on apex 2.0 beta .591 deodoxed running watermark and stealth themes, should I expect problems using multi themes on top of each other. Thanks for advice.
    Apex 2.0 Beta
    Moderator
    Points: 25,450, Level: 96
    Frequent Poster
    mikeinrichmond's Avatar
    9010
    Richmond, Va
    7,668
    392 times
    Yes, one theme can leave remnants behind and may eventually cause issues. The best idea is to make a backup in clockwork of the Rom you're running while its stock, then restore back to that first before you install another Theme.. A bit picky, yes, but it works..
    patrick72's Avatar
    22485
    55
    Thanks. Just trying new theme and being lazy.
    Apex 2.0 Beta
  1. Replies: 832
    Last Post: 04-24-2011, 08:14 PM
  2. Any 1v1 multi player games available for the x?
    By Dvan in forum Droid X Games
    Last Post: 03-01-2011, 06:01 PM
  3. multi picture wallpaper?
    By thewakka1 in forum Droid X Wallpapers
    Last Post: 11-24-2010, 08:31 PM
  4. Droid X 2.2 rooted running offical OTA themes
    By C5O in forum Droid X Themes
    Last Post: 09-29-2010, 06:27 PM
  5. Gtalk unread and multi mms
    By TMFGO45 in forum Droid X Help
    Last Post: 09-20-2010, 07:16 PM
