Multi-ROM Release Thread - Blur-Based ROMs for those on .621/.604 rooted!
These ROMs are designed just for those who want a blur-based ROM and are on the Milestone X SBF root from .621; if you are not, do not flash!
**READ**
Here is where I am going to be posting updated ROM files for blur-based ROMs for those who are on the .621/.604 rooted. Currently, if you try to flash the normal version of a blur-based ROM (one that works on .602/.605) you will get a bootloader error. I am in the process of patching these ROMs to work on the .621/.604 system version. I am currently contacting developers to get their permission to patch their ROMs and release them here. I have released all that I've had patched so far. If you are a developer and see your ROM listed here and do not want it here for whatever reason, PM me and I will remove the link. I am just providing these in the interest of the community. All credit for original work goes to the original developers of these ROMs!
**FIXES - THESE ARE FOR ALL BLUR-ROMs ON THE .604 HACK**
.621 kernel, recoveries, CDT, device tree
This will put you on the correct kernel for the DX, instead of the MX .604 kernel. Credit to ky41083 @Rootz for this [Link]
Download:
http://www.mediafire.com/?b4fndlwkcf8icfn
MD5: 1D2EE9260E6C7510292B1AF5F7D6ACC1
.621 WIFI Lib Fix
This will fix your WIFI so auto DHCP will work, no longer requiring the static IP fix. WIFI should work as normal.
Download:
http://www.mediafire.com/?969b4y3hc55bcwl
MD5: 5A45A5A102F62BE22CF89B0BE84145EDLet us begin!
Apex 2.0.0 RC4
Developer: Fabulous
Original Thread (Donations, etc.):http://rootzwiki.com...te-rc4-1092011/
File Download:http://www.mediafire...fi7saduxteiaaal
MD5:32527894143E006F3CD3838F2D15F009
Liberty 3 v2
Developer: Liberty Team
Original Thread (Donations, etc.):http://rootzwiki.com...-bloody-sunday/
File Download:http://www.mediafire...4t72dipau2c8i1g
MD5:13F579936ABBB4967F4BF226747EC6B0
Shuji 2.5
Developer: mobile_sensei
Original Thread (Donations, etc.):http://rootzwiki.com...huji-rom-25-dx/
File Download:http://www.mediafire...h0uku25ckysi2bn
MD5:EA90CBB2899D3238521FC793EC171E19
Stock-Rooted-Deodexed .605
Original Thread (Donations, etc.):http://rootzwiki.com...deodexed-45605/
File Download:http://www.mediafire...bujzi0ll619jbtf
MD5:55C55FB4EDE66D7E7108F26215AA9406
VorteX RC1
Developer: deVorteX
Original Thread (Donations, etc.):http://rootzwiki.com...ease-candidate/
File Download:http://www.mediafire...t1mb5ix3mdkit8j
MD5:4E80A2176576522C92F462996BFD5331
These ROMs are community support ONLY! While I am flashing each of these individually to ensure they boot with no issues before releasing, do bear in mind that because you are on the new system version developers are not easily able to help you, as none of them are currently on the new system version! If you have any issues with the ROM, search the original thread for known issues and/or answers, failing that post here, and we can try to assist you as needed. All should work fine though as I said, as I am testing these prior to release!
Install Instructions:
Follow instructions in OP of original thread. When I am testing these for install I always perform the mini-SBF to eliminate issues.
Boot in to CWM.
Wipe data/factory reset
Wipe cache partition
Wipe dalvik cache (under Advanced)
Format system (under Mounts and Storage)
then install the desired .zip.
then install fixes (kernel then WIFI) no wipes with either.
Known Issues:
None ATM. Just make sure you apply the kernel patch and the WIFI patch (I'll see about getting these integrated into the ROMs themselves one of these days.)
This is copied from the main thread @Rootz, that's my usual haunts. Just providing it here for you folks @DXF to enjoy. I'm over here fairly often so I'll try be around to respond if you have questions, and update the OP with new builds, etc, but main Dev thread is here:
[ROMS] Multi-ROM Thread - Blur-Based ROMs for those on .621/.604! - RootzWiki
