[ROMs] Multi-ROM Thread - Blur-Based ROMs for those on .621/.604!
This is a discussion on [ROMs] Multi-ROM Thread - Blur-Based ROMs for those on .621/.604! within the Gingerbread Roms forums, part of the Gingerbread Development and Hacking category; Goose, Would you consider making a patch for Xcellerated? http://rootzwiki.com/topic/215-rom-x...ery-mod/page-1 I have to, once again, express my gratitude for the other ROMs you have patched. ...
Page 16 of 16 FirstFirst ... 6141516
Results 151 to 158 of 158
Like Tree8Likes
Thread: [ROMs] Multi-ROM Thread - Blur-Based ROMs for those on .621/.604!
  1. #151
    Points: 2,987, Level: 33
    Level completed: 58%, Points required for next Level: 63
    Overall activity: 5.5%
    Toad's Avatar
    54722
    Jan 2012
    Idaho Falls, Idaho
    61
    Goose,
    I have to, once again, express my gratitude for the other ROMs you have patched. They are so fun to try out, work with, play with... You've kept my X interesting.
    Thank you!
    Sent from my DROIDX
    Running on Goose's Patched Shuji
    Using Droid X Forums
  3. #152
    Hey guys i'm new here. Love the forums. Just trying to see if anyone can help with my problem. I would appreciate it.
    Basically after installing d2bootstrap and rebooting into cwm; Did the wipes and format.I flashed the kernel and wifi fixes first before flashing the shuji rom(Mistake). I didn't put the rom on my SD before i started.
    So now It wont go pass M logo and I don't know how to get into cwm again.
    Just in case-I can get into bootloader and stock recovery.
    Again Thanks,
    Rubix
  4. #153
    Points: 18,614, Level: 86
    Level completed: 53%, Points required for next Level: 236
    Overall activity: 19.6%
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    Quote Originally Posted by Rubix9 View Post
    Again Thanks,
    Rubix
    try wiping data in android recovery see Hard Reset via Android Recovery
    if that doesn't work you will need to flash a sbf
    try 1KDStaz_DX_4.5.605.iso
    from here Linux solution to your Windows/RSD lite problems
    or
    VRZ_MB810_4.5.605_1FF_01.sbf
    following
    Using
    RSD Lite to flash a .SBF to restore (Stock Rom).
  5. #154
    Ok just tried wipe data in stock recovery. Same thing. Also early before i posted. I tried 1KDStaz_MX_4.5.604.iso, booted up the distro, but it stopped/froze at connecting to phone(after selecting option 1). Never did detect it. I'll try the other two. Ill post back. Thanks
  6. #155
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    phone was in bootloader?
    use rear usb ports, rather than front
  7. #156
    In bootloader. Though i am using a front port.
    Seems like its going through: uploading CG39-50%
    come on...
  8. #157
    Nope didnt work. Now im back to
    Bootloader
    30.04
    Err:A5,70,70,00,1F
    MEM_MAP Blank
    Service Req'd
    Battery OK
    Ok to program
    Transfer mode:
    USB
    I ran into this before. Its why i install the 1KDStaz_MX_4.5.604.iso to get my phone back working(Before this new problem).
  9. #158
    Ok Got it working by again reflashing 1KDStaz_MX_4.5.604.iso.
    Thanks shadow
  1. Flashing MIUI Lockscreens on CM7 based ROMS
    By goldsmitht in forum MIUI
    Last Post: 08-16-2011, 12:09 PM
  2. Swype beta and cm7 based roms?
    By silver04v in forum Gingerbread General Discussion
    Last Post: 08-05-2011, 09:19 PM
  3. Voicemail on cm7 based Roms. Help Please!
    By silver04v in forum Gingerbread Roms
    Last Post: 07-31-2011, 10:32 PM
  4. Bootloader limiting cm7 based roms at all?
    By Dvan in forum Cyanogenmod
    Last Post: 07-20-2011, 06:45 AM
  5. Bootloader limiting cm7 based roms at all?
    By Dvan in forum Gingerbread Roms
.604 roms
.621 roms
droid 621 rom
droid x .604 roms
droid x .621 roms
droid x 621 roms
droid x blur roms
gingerbread roms for droid X
liberty rom 3 droid x 604
milestone x .604 roms
