[ROMs] Multi-ROM Thread - Blur-Based ROMs for those on .621/.604!
This is a discussion on [ROMs] Multi-ROM Thread - Blur-Based ROMs for those on .621/.604! within the Gingerbread Roms forums, part of the Gingerbread Development and Hacking category; ROM and patches should be on the SD card prior to step 5. And during the process of installing Clockwork grant Superuser permission when it ...
Page 12 of 16 FirstFirst ... 2 10 11 12 13 14 ... LastLast
Results 111 to 120 of 151
Like Tree7Likes
Thread: [ROMs] Multi-ROM Thread - Blur-Based ROMs for those on .621/.604!
  1. #111
    Points: 3,098, Level: 34
    Level completed: 32%, Points required for next Level: 102
    Overall activity: 7.9%
    newmanx4's Avatar
    34469
    703
    27 times
    And during the process of installing Clockwork grant Superuser permission when it asks for it.
    Sent from my Black Iced X
  3. #112
    Quote Originally Posted by newmanx4 View Post
    You'll still need the files on the card. Redo the .604 Linux method to get the phone working. May require a factory reset afterwards to get it to boot. Then root the phone(unless you're using the live CD method, then just root it in the same session). Once its rooted follow these steps.
    1. Install Droid 2 Bootstrap
    2. Install ROM Manager Lite.
    3. Open D2 Bootstrap. Hit Bootstrap Recovery. Close the app.
    4. Open ROM Manager. Select Install Latest Clockwork. Should be the top choice. When the device list pops up choose Droid X 2nd init.
    5. In ROM Manager choose Reboot Recovery. Phone will boot into Clockwork. Black screen with blue text.
    6. Once in Clockwork do a data wipe and cache wipe.
    7. Install ROM zip from SD card.
    8. Reboot
    9. Once you're booted you can boot back into recovery and flash your patches. I've never run Liberty, but on most ROMs you hold down the power button which brings up a menu where you choose Reboot->Recovery. If it doesn't then reboot through ROM Manager again to get there. Flash the patches without doing any wipes and reboot.
    One thing: Once you've used Bootstrap, NEVER hit Bootstrap Recovery again or you'll be starting from scratch again.
    I'm on day 4 of trying to get this thing to work. I'm about to give up on Liberty(same one posted on OP)....
    I tried the above, and when installing that Liberty ROM it runs than goes about four lines to "Installation Aborted"
    Anyone have any good suggestions on a ROM that actually works?!?
  4. #113
    Points: 7,176, Level: 56
    Level completed: 13%, Points required for next Level: 174
    Overall activity: 30.9%
    1,340
    78 times
    Quote Originally Posted by tmoney728 View Post
    All the ROMs listed in the OP work perfectly fine. I tested them all on my DX running .621 prior to releasing them as the patched versions.
    What is the error it is giving you specifically. Does it say something "Status 7: Installation Aborted" does it say "Signature Verification Failed" or something similar; what is it specifically telling you. That will help us figure out the source of the problem.
    Also, what is the background of your recovery. Andy the Android with an exclamation or the black hat with an arrow around it? If its a black hat is the text green or blue?
  5. #114
    I'm not sure if this was asked or cleared up somewhere in this thread, but I have a question.
    In the instructions for the .621 kernel, it says to flash desired .zip and THEN flash the kernel/wifi fix. I am extremely new at all this, but aren't you supposed to have flashed the kernel before you flash a rom?
  6. #115
    cant get droid x to boot.
    i have tried this and all other stuff on my droid x. i got it rooted on the milestone x .604. i get root access but when i try to install a rom it installs but it does not boot. i get stuck at the motorola logo and nothing happens. please if anyone is having this issue and has found a way to fix it reply back. i would really apreciate it. i got root access through the zergrush.
  7. #116
    Points: 729, Level: 14
    Level completed: 29%, Points required for next Level: 71
    Overall activity: 0.6%
    zuzto's Avatar
    58343
    May 2012
    31
    I did in that order and works for me.
    1. Kernel fix
    2. Rom
    3. Wifi fix.
    In the case of second init just the rom.
    Enviado desde mi DROIDX usando Tapatalk
  8. #117
    zuzto's Avatar
    58343
    May 2012
    31
    U need read the entire post bro.
  9. #118
    Got it!
    Did all the stuff in the right order and got it to bootloop which was actually kind of a shred of hope in this grueling process. Before, I was bricking my phone over and over. Finally sbf, root, cwm, wipes, 621 fix, rom, wifi fix, reboot and... it booted up to my surprise.
    I am now running APEX!!!
    Very exciting. Anyways, still working on getting everything setup and whatnot, but the moment of truth comes when I try the wireless tethering. That's really the ultimate goal of all this anyway, so here goes.
    Edit: Failed
    After I successfully flashed the apex rom, and downloaded 'Wireless Tether for Root Users' it sets up fine and I can connect to it with my laptop, but it takes me to the web page that makes me sign up for the service through verizon. Is there some way around this? Should I be using a different app? While I wait for replies, I'm gunna try a couple things.
  10. #119
    zuzto's Avatar
    58343
    May 2012
    31
    I dont know apex, i use vortex and the wifi tether works fine.
  11. #120
    I found a guide to get wifi tethering working after rom flash. It had me use the RadioComm program and do a couple things, and download a specific app for tethering. After all that, it doesn't take my to the verizon setup page, so all is good now!
  1. Flashing MIUI Lockscreens on CM7 based ROMS
    By goldsmitht in forum MIUI
    Last Post: 08-16-2011, 11:09 AM
  2. Swype beta and cm7 based roms?
    By silver04v in forum Gingerbread General Discussion
    Last Post: 08-05-2011, 08:19 PM
  3. Voicemail on cm7 based Roms. Help Please!
    By silver04v in forum Gingerbread Roms
    Last Post: 07-31-2011, 09:32 PM
  4. Bootloader limiting cm7 based roms at all?
    By Dvan in forum Cyanogenmod
    Last Post: 07-20-2011, 05:45 AM
  5. Bootloader limiting cm7 based roms at all?
    By Dvan in forum Gingerbread Roms
.604 roms
droid x .604 roms
droid x .621 roms
droid x 621 roms
droid x blur roms
droid x development multi rom thread
droid x roms .621
gingerbread roms .621
liberty rom 3 droid x 604
multirom flasher s2
