Want GB rom that can tether using wifi tether and have good battery life
This is a discussion on Want GB rom that can tether using wifi tether and have good battery life within the Gingerbread Roms forums, part of the Gingerbread Development and Hacking category; I've been out of the GB rom scene since august. All I've been doing is hating the battery life on CM7 nightly builds with froyo ...
Results 1 to 10 of 13
Thread: Want GB rom that can tether using wifi tether and have good battery life
    Points: 1,667, Level: 23
    Level completed: 67%, Points required for next Level: 33
    pheonix991's Avatar
    6726
    46
    I've been out of the GB rom scene since august. All I've been doing is hating the battery life on CM7 nightly builds with froyo kernel.
    So, here is what I do on my phone, text, use navigation, use camera, use browser, wifi tether(non verizon app), stream music, oh, and make calls.
    Anyone wanna give me suggestions on a GB rom that has good battery life, and can do wifi tether? Or am I stuck having to go back to froyo?
    Points: 5,929, Level: 49
    Level completed: 90%, Points required for next Level: 21
    Overall activity: 3.4%
    milski65's Avatar
    37085
    Orange, Va
    1,010
    15 times
    Quote Originally Posted by pheonix991 View Post
    As many will probably post, vortex rc1. Just need the wifi beta 3.1 version 6 or 7 apk (others may work as well). Completely reliable rom, great battery life (do calibrate). Think you'll enjoy it.
    pheonix991's Avatar
    6726
    46
    Quote Originally Posted by milski65 View Post
    Since it's a 605 based rom, and I'm on froyo kernel cm7, so I switch to an OTA 605, or is there a rooted one that I flash over what I have now?
    Then how about the .13p radio? When do I flash it?
    Thanks for the help.
    Points: 6,372, Level: 52
    Level completed: 11%, Points required for next Level: 178
    savagerun's Avatar
    41501
    2,204
    54 times
    You can flash the 13 baseband now if you want. Boot into clockwork recovery and flash this http://dl.dropbox.com/u/11695745/DXC...201.09.13P.zip. You can flash that baseband zip without doing any wipes. You can then do an sbf to get you on. 602 just do the 1KDS 602 iso found here GB.602! ROOT! Start here! Links to all. And after the sbf you can take the OTA to get you on 605 then just root that with the d3 one click root also found in the link. There's videos in that link to show you how to sbf and root. Once rooted get droid 2 bootstrap and make a nandroid backup of your rooted 605 then install vortex.
    pheonix991 likes this.
    pheonix991's Avatar
    6726
    46
    Quote Originally Posted by savagerun View Post
    You can flash the 13 baseband now if you want. Boot into clockwork recovery and flash this http://dl.dropbox.com/u/11695745/DXC...r 1.09.13P.zip. You can flash that baseband zip without doing any wipes. You can then do an sbf to get you on. 602 just do the 1KDS 602 iso found here GB.602! ROOT! Start here! Links to all. And after the sbf you can take the OTA to get you on 605 then just root that with the d3 one click root also found in the link. There's videos in that link to show you how to sbf and root. Once rooted get droid 2 bootstrap and make a nandroid backup of your rooted 605 then install vortex.
    AWESOME! You've helped a ton.
    pheonix991's Avatar
    6726
    46
    Vortex is exactly what I wanted. I've had it off the charger since 8am yesterday, it's almost 1030am now, and only at 50% battery life. THANKS!
    milski65's Avatar
    37085
    Orange, Va
    1,010
    15 times
    Glad you got it up and running. Savage did an awesome job with the instructs.
    Points: 876, Level: 15
    Level completed: 76%, Points required for next Level: 24
    Overall activity: 1.5%
    lukethouin's Avatar
    45654
    Aug 2011
    12
    Miui 1.10.28
    Points: 45,910, Level: 100
    DirtyDroid's Avatar
    28665
    Upstate,NY
    14,576
    384 times
    Quote Originally Posted by lukethouin View Post
    Miui 1.10.28
    True but also uses ad-hoc connection must be able to connect, some cant
    Points: 1,159, Level: 18
    Level completed: 59%, Points required for next Level: 41
    peon883's Avatar
    52942
    Dec 2011
    110
    Wow I am running vortex and have a trident extended battery and only get 10 hours of use from a charge
    Sent from DROIDX / vortex rc1
  1. Wifi tether
    By Dragonicnight in forum Droid X2 Support
    Last Post: 10-24-2011, 12:05 AM
  2. Wifi tether
    By towbiz in forum Droid X General Discussion
    Last Post: 08-15-2011, 10:09 AM
  3. Root WiFi Tether/WiFi 3G HotSpot GB 595
    By evams in forum Gingerbread Development and Hacking
    Last Post: 07-31-2011, 01:45 PM
  4. Wifi tether
    By Matt127 in forum Gingerbread Development and Hacking
    Last Post: 07-31-2011, 11:37 AM
  5. Whats a good app to wireless tether?
    By DroidXDoes in forum Droid X Hacks
    Last Post: 04-30-2011, 05:33 PM
android wifi tether droid x gingerbread
android wifi tether gingerbread
cm7 droid x hotspot
do 2nit roms have betger batt life than gingerbread droidx
droid x gb roms
gingerbread wifi tether
i have a rooted droid x and want to tether it
wifi tether app for rooted droid x gingerbread 605
wifi tether droid gingerbread
wifi tether gingerbread droid x
