Stuck on MIUI
This is a discussion on Stuck on MIUI within the Gingerbread Roms forums, part of the Gingerbread Development and Hacking category; Flashed MIUI rom for DX now I can't reboot into recovery. Any help would be appreciated Sent from my DROIDX using Droid X Forums...
Results 1 to 10 of 10
Thread: Stuck on MIUI
    Points: 1,605, Level: 23
    Overall activity: 4.5%
    eppdroid37's Avatar
    50829
    Nov 2011
    95
    Stuck on MIUI
    Points: 4,159, Level: 41
    Level completed: 5%, Points required for next Level: 191
    Scram's Avatar
    36066
    Jersey Shore
    492
    10 times
    Which update did you flash??? Try holding power button, if clockwork recovery is there select it... If you are on a more recent update, reboot phone, when led flashes blue for a second or two hit volume down... Then select recovery.
    Shot out by DXC's MIUI 10.21...
    eppdroid37's Avatar
    50829
    Nov 2011
    95
    1.11.9
    Points: 786, Level: 14
    Level completed: 86%, Points required for next Level: 14
    Overall activity: 0.7%
    Rugman55's Avatar
    29220
    Brunswick, GA
    13
    Power off. Power on and when you see blue led press volume down and select latest recovery.
    eppdroid37's Avatar
    50829
    Nov 2011
    95
    Thanks for the help guys. Back on good ole VorteX.
    Scram's Avatar
    36066
    Jersey Shore
    492
    10 times
    Ah, Vortex. Very nice. Always have it on deck myself... glad to help
    shot out from DXC's MIUI 10.21... BOOM!!!
    Points: 1,233, Level: 19
    Level completed: 33%, Points required for next Level: 67
    zuzto's Avatar
    58343
    May 2012
    31
    Hi people... i just had this problem... im stuck in MIUI, but, after a lot of trays with bootstrap and rom manager, the MIUI dont show the leds in the Turn on, so, i cant get into recovery.
    My phone turn on with the M of motorola, and stays there like.. 3 minutes, after begin the MIUI boot but without the leds... so, i want to change the ROM cause the camera just dont work ok, take pictures blur, i dont know why, so, please, somebody gimme a light here, what can i do? i dont care if the methos is not easy, i want to get out of MIUI.
    Thanks in advance and excuse my poor english.
    Points: 8,909, Level: 63
    Overall activity: 43.1%
    1,340
    79 times
    Quote Originally Posted by zuzto View Post
    If you've been using bootstrap you broke your recovery. Never use bootstrap on MIUI or any 2nd-init ROM as its breaks it. The recovery option is built-in.
    What version of MIUI are you running? Some earlier versions didn't have the bootmenu built-in.
    As far as the blurry pictures, its a known issue. Set the autofocus to Infinity and it should resolve it.
    If you *did* use bootstrap and choose "Bootstrap Recovery" and you are on one of the latest versions you are probably not getting a blue LED due to the fact that the bootmenu is in the hijack.zip now. So you break recovery=you break bootmenu, generally. You may try going to ROM Manager, choosing to update CWM Recovery, then choose Droid X 2nd-init, and then choose either reboot recovery or the power-down menu. This may work, depending on which version you are on. If you are on a real old version (like from December) you may need to run the cat.jpg script. So, check your version and see.
    zuzto's Avatar
    58343
    May 2012
    31
    My MIUI version is
    2012.2.1
    And yes, i used the bootstrap and the rom manager and rom box or something like that, so, i already broke the ini and the boot and i cant change themes either, so, i really messed up i think... so, please let me know how to fix it...
    Thanks in advance.
    zuzto's Avatar
    58343
    May 2012
    31
    Hi people...
    Well... i fix the problem, i flash with a linux bootable disc with version 4.5.605 or something like that... but...
    First, i update to 4.5.621, so i lost root... so... i flash with the linux disc boot... and then... ok... i got root... but...
    why in the status still show mi phone number? my prl? my min? why is not like new?? im in mexico so... im in IUSACELL, this is a verizon phone... but... was running ok... working ok, but i update, so, i lost root, and then... bla bla...
    Right now i dont have data, not calls, not sms, nothing... is just a nice pocket pc... but my min and phone number and PRL stills show in the status, why is that??
    Thanks in advance.
  1. Stuck in ics miui.
    By SupraRZ95 in forum MIUI
    Last Post: 11-28-2011, 05:56 PM
  2. Replies: 21
    Last Post: 11-18-2011, 03:00 PM
  3. Stuck in miui
    By towbiz in forum Gingerbread Development and Hacking
    Last Post: 11-06-2011, 03:26 PM
  4. Replies: 6
    Last Post: 09-26-2011, 09:56 PM
  5. Replies: 18
    Last Post: 08-06-2011, 10:11 PM
droid razr stuck on miui rom
droid x miui reboot recovery
droid x miui recovery
droid x miui stuck
droid x stuck on miui
droid x stuck on miui boot
miui can't boot into recovery
miui droid x recovery
miui recovery reboot
stuck on miui droid x
