Gingerbread, and 2nd init roms, what are you running now or like the best and why.
This is a discussion on Gingerbread, and 2nd init roms, what are you running now or like the best and why. within the Gingerbread Roms forums, part of the Gingerbread Development and Hacking category; I know people have issues with the guy. I understand why and don't blame them. But it doesn't bother me much. Its wrong what he ...
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 46
Like Tree16Likes
Thread: Gingerbread, and 2nd init roms, what are you running now or like the best and why.
    Points: 1,868, Level: 25
    Overall activity: 3.2%
    akeezy's Avatar
    35474
    289
    17 times
    I know people have issues with the guy. I understand why and don't blame them. But it doesn't bother me much. Its wrong what he did but I haven't used the "kanged" work. He definitely made some good roms on his own. Snowy blur was my first on froyo. And broodcomb 2 was indescribably amazing. Genesis though is no shuji(unless someone proves me wrong). Shuji is source and genesis has all the blur elements and I think Genesis was out first. After that fiasco a couple months ago with apex I've stayed away but I'm on gingerbread now from 2nd init and Genesis is the only rom keeping me happy.
    I installed zombiestomped from fresh 595 and after that first day and a half of battery drainage, it rebooted continuously. Did a wipe of everything and reflashed and same results. Sbf'ed and went back to gingy and it happened again. I'm going to try again if genesis gives me any issues.
    I tried liberty once on froyo and wasn't satisfied. I didn't like the feel of it. I was on it for 3 hours before I couldn't take it anymore haha. Broodcomb 2 and zombiestomped are the only other gingerbread roms I like most
    From akeezy's Galaxy
    SscoootzZ likes this.
    Points: 3,237, Level: 35
    Level completed: 25%, Points required for next Level: 113
    cw0974's Avatar
    880
    267
    i'm currently on miui 1.8.5 and have been on cm7 til miui. Before i go into anything, i run adw launcher with both. didn't like the stock miui.
    Personally, cm7 worked great for me. I didn't have any bugs or problems. I think cm7 is my choice from the two. With miui, i get 15-20% more battery life than cm7 and i really love the mix and match theme i can put on it. However, miui with adw is running a bit laggy for me. I might move back to cm7 later, but for now i like my set up on miui. Will stay for a bit.
    Points: 6,741, Level: 53
    Level completed: 96%, Points required for next Level: 9
    Overall activity: 5.5%
    3 months registeredTagger Second Class100 Experience Points31 days registered7 days registered
    griz.droidx's Avatar
    31474
    Southwest Virginia, In the Boonies/Bible Belt/Coal Bucket
    262
    @akeezy, I understand man, as I may have mentioned, I've heard the guy does good work on his own. I did try a couple of his roms before all the hoopla started. So, you don't like aosp roms? Do you mean 596 aosp or CM7 aosp? Just wondering. And I don't understand the constant reboots on Zombie, I never had that problem before (back around the first of June). I'd like to try that one again, but I'm not gonna go back to 595, cause it seems like too much work just getting back to 595. Have you tried DSX? It's a nice blurry rom. And wulf has some really nice theme's built for it.
    I'm back on Lib v.9 I had never tried .9 and wanted to check out battery life on a 596 rom. From what I've read though, the 596 stock liberties aren't known for stellar battery life. I ran V6 yesterday. battery is holding up well, but I'm not sure how well yet. I really miss all the features of the CM7 and 2nd init roms.
    I've been reading on the new MIUI release, and it seems to be a bit buggy from what I've read. Various people having various issues. One person said he never saw a prob with it except for changing ringtones which everyone else had problems with too. I've definitely got the itch. May try CM7 60. I haven't been on a standard CM7 in a long time. I used liquid per your recommendation from a while back and really liked it.
    Thanks to everyone who has replied. Thanks.
    X Pursuant Achievements:
    fernbch's Avatar
    45190
    Aug 2011
    Fernandina Beach, Fl
    642
    8 times
    I, too, am interested in 2nd init and am just starting my info quest. I may have misunderstood something I read elsewhere, but does 2nd init allow for the use of a modded kernel? Also, in the OP, DarkSlideX is mentioned. Is it a 2nd init rom? I'm currently running it and was unaware of possible 2nd init status.
    My Droid Thrives on the DarkSlide!!!
    Sent from the pc, but the Droid still lives...........
    akeezy's Avatar
    35474
    289
    17 times
    I do like AOSP. But I prefer the 2nd init AOSP because motoginger in my opinion should be motoginger and to turn 596 into AOSP ginger is basically another source rom w/o the extra customization. I came back to motoginger primarily for zombiestomped so I could enjoy the motoblur, great battery life, and I missed the camera haha. And now im just staying on genesis because his roms have always been easy to use with no issues for me ever.
    As for Darkslide, it's much too busy in terms of looks to me. It's well themed but im a minimalist kind of guy and all the colors and stuff going on gives me headaches haha. I always try to find a simple black and white theme on roms.
    MIUI was great at first but frustrated me. I couldn't stay on it for more than a few hours at a time and just gave up on it. When I try zombie again, if it continues to reboot, I'll move back to liquid
    akeezy's Avatar
    35474
    289
    17 times
    Quote Originally Posted by fernbch View Post
    I don't know about the modded kernel on 2nd init but I don't think you need it. 2nd init allows source based roms to work on the froyo kernel. Darkslide is not 2nd init. It's on the gingerbread kernel
  8. #17
    Points: 1,534, Level: 22
    Level completed: 34%, Points required for next Level: 66
    MIck11's Avatar
    27246
    48
    I'm on justice and it is great with no bugs at all
  9. #18
    Points: 29,424, Level: 99
    Nemo aeternamn's Avatar
    37333
    Mo-ab
    7,738
    165 times
    I've run all of the 2nd init roms... Justice and cm7 are my favorites... Liquid 2.6 was also great... Love the feel and the speed... Especially the customization with the t mobile theme chooser engine... It's amazing... And undervolted and running the v6 script... Also getting decent battery life...
    Post Script:
    Nemo Aeternamn Wallpapers
  10. #19
    Points: 2,291, Level: 28
    Level completed: 94%, Points required for next Level: 9
    tribals's Avatar
    37767
    125
    Currently on Liberty gb v.9 and loving all the options. I'm getting very good battery life and it runs so smooth ....no issues.
    I was on Darkslide X which was good too, but I like Liberty better.
    I am waiting as well to see if they work more of the bugs out of MIUI then I'll give that a try.
    Liberty v.9/Watermark theme/OC'd
  11. #20
    Points: 1,969, Level: 26
    Level completed: 69%, Points required for next Level: 31
    lehman70's Avatar
    21524
    165
    I just flashed CM7 build#60 tonight Griz. I'm gonna run it stock for one charge to see how it does. Then I'll undervolt and see how it works. I'll let you know how it goes.
  1. [HOW TO] BE READY to FLASH GB/2nd-INIT ROMs
    By macpro88 in forum Gingerbread Development and Hacking
    Last Post: 11-30-2011, 01:33 PM
  2. Gingerbread kernal 2nd init... New radio update
    By dj923 in forum Gingerbread Roms
    Last Post: 08-18-2011, 06:59 PM
  3. 2nd-INIT roms
    By B1GD in forum Gingerbread Help
    Last Post: 08-04-2011, 12:37 PM
  4. 2nd init roms: animation issues
    By kochoid in forum Gingerbread Roms
    Last Post: 07-28-2011, 01:25 AM
2nd init rom
2nd init roms
2nd init roms droid x
best 2nd init rom droid x
best droid x gingerbread rom
droid x 2nd init
droid x 2nd init roms
second init
what are 2nd init roms
what is a 2nd init rom
