How do I update my ROM and keep my current settings/setup?
This is a discussion on How do I update my ROM and keep my current settings/setup? within the Gingerbread Roms forums, part of the Gingerbread Development and Hacking category; I am running liquid GB v2.3 and wanted to update to v2.4. How do i do this and keep all of my current settings and ...
  • 1 Post By JNEHAMA
Thread: How do I update my ROM and keep my current settings/setup?
    Points: 1,222, Level: 19
    Level completed: 22%, Points required for next Level: 78
    Overall activity: 0.6%
    anderbutter's Avatar
    38609
    43
    I am running liquid GB v2.3 and wanted to update to v2.4. How do i do this and keep all of my current settings and setup? I just want to keep everything how it is and just update, not start from scratch building my home screens, adjusting my settings, etc. Also using ADW launcher. Thanks!
    Points: 5,992, Level: 50
    JNEHAMA's Avatar
    28370
    Long Island New York
    1,205
    65 times
    Quote Originally Posted by anderbutter View Post
    Fortunately, you can flash 2.4 over 2.3 without a data wipes. Download 2.4 and verify file size and optimally md5sum. Go into CWM the gold recovery and make a backup of your current setup just in case. The clear cache and dalvick cache, then install 2.4, then reboot system. Make sure to start with a full charge, again just in case. You will have an extra long bootup and may even need to do a battery pull and boot up a second time. Just wait through it and you will be on 2.4. The only thing you will loose is if you made any framework modifications eg. Metamorphosis, ninjamorph.
    anderbutter likes this.
    38609
    43
    didnt work.... i mean, i kept all of my apps but it restarted with launcher pro, i had to re-download ADW. before updating, i backed up ADW settings and desktop configuration, and when i restored them it restored the theme only not my home screens and widgets... i just want it to basically update and keep everything else how it was, its just too much of a hassle to do all this stuff over every time i update or flash a new rom
    RS Team Leader
    Points: 26,927, Level: 97
    Level completed: 58%, Points required for next Level: 423
    Overall activity: 99.9%
    Activity Award
    popcenator's Avatar
    21238
    Omaha, NE
    8,258
    179 times
    You're settings will be reverted to the stock ROM settings because flashing the next version overwrites any changes you made.
    on the move..
    Points: 5,393, Level: 47
    Level completed: 22%, Points required for next Level: 157
    Overall activity: 0.7%
    chuck54's Avatar
    41016
    697
    Use titanium and it will restore it all. It worked from 2.5 to 2.6
    Sent from my DROIDX running liquid 2.6 while my Chevy (ssx) is broke..... boohoo
    I'm diagnosed with a severe case of noobecidis, it might not be treatable...
  1. Replies: 3
    Last Post: 06-27-2011, 10:32 PM
  2. ROM setup
    By B1GD in forum Droid X Help
    Last Post: 05-18-2011, 09:47 AM
  3. Will this setup work for a ota update?
    By bullysonx in forum Droid X Hacks
    Last Post: 02-21-2011, 09:43 AM
  4. K9 setup
    By Westone in forum Droid X Help
    Last Post: 11-03-2010, 04:09 PM
  5. What's Your Current Setup?
    By psychotic_penguin in forum Droid X General Discussion
    Last Post: 09-30-2010, 11:16 PM
how do i update my rom
how to update my rom
keep my current settings ne demek
keep my current settings traduzir
keep my current settings.
o que significa keep my current settings
traduzir keep my current settings
