Replacement phone -- will I be able to root it? (if on gingerbread when it arrives)
This is a discussion on Replacement phone -- will I be able to root it? (if on gingerbread when it arrives) within the Gingerbread Roms forums, part of the Gingerbread Development and Hacking category; As the title says, VZW is sending me a replacement DX, but I am wondering whether I will be unable to root it if it ...
Thread: Replacement phone -- will I be able to root it? (if on gingerbread when it arrives)
    lordloki's Avatar
    15346
    26
    As the title says,
    VZW is sending me a replacement DX, but I am wondering whether I will be unable to root it if it arrives with OTA already installed (which I would imagine is reasonably likely).
    Thoughts?
    Much appreciated in advance.
    Developer
    Developer
    Points: 13,682, Level: 76
    Level completed: 8%, Points required for next Level: 368
    Fabolous's Avatar
    15069
    168
    193 times
    Absolutely. You can still SBF back to .340 and go through the steps to get back to .596 rooted.
    Points: 1,970, Level: 26
    Level completed: 70%, Points required for next Level: 30
    dig'em's Avatar
    5997
    307
    9 times
    I got a vzw replacement phone last week and it was on froyo.
    That was last week though...
    If on GB, just sbf back to froyo and root it. Then u can get the rooted GB or whatever u want
    lordloki's Avatar
    15346
    26
    Quote Originally Posted by Fabolous View Post
    Quote Originally Posted by dig'em View Post
    brilliant. i was concerned when i saw that OTA wasn't root-able. So they didn't change the bootloader key between froyo and GB? sounds like VZW has given up protecting the DX from rooting. previously, you couldn't SBF back to older builds.
  1. Replies: 1
    Last Post: 06-08-2011, 10:11 PM
  2. Gingerbread arrives for the Droid X (not OTA)
    By Garemlin in forum Everything about Gingerbread
    Last Post: 01-31-2011, 02:28 PM
  3. Replies: 4
    Last Post: 01-22-2011, 08:55 AM
  4. Replies: 3
    Last Post: 12-02-2010, 09:56 AM
  5. Do you think I should ask for a replacement phone?
    Last Post: 07-24-2010, 02:28 PM
android rooting a replacement phone
got a replacement droid need to root it
zroot gringerbread
