Best drew garen rom?
This is a discussion on Best drew garen rom? within the Gingerbread Roms forums, part of the Gingerbread Development and Hacking category; Which one is the best? Sent from my DROIDX using Droid X Forums...
Results 1 to 10 of 16
Thread: Best drew garen rom?
    jarrod138's Avatar
    35466
    12
    Points: 3,539, Level: 37
    Level completed: 26%, Points required for next Level: 111
    Jersey's Avatar
    34389
    900
    Depends on what your looking for out of it
    Points: 4,487, Level: 42
    Level completed: 69%, Points required for next Level: 63
    Overall activity: 1.2%
    rudyy's Avatar
    30693
    california
    738
    11 times
    yes, and some are for. 591 kernel, others for. 595.
    i'm running zapx ginger 4.3, and it's stable, seems fast enough, was easy to install (though i had to replace the boot animation, and just noticed, after hours of running the rom, i'd lost my 3g signal. reboot fixed it.)
    would like to see some themed apps besides the ones i already had.
    if your a social networking type, the rom comes with plenty. i'm not, so i froze them.
    i've also tried lexlite 4.4, but i'm happier with zapx, though i cannot explain why. maybe the second time around made it better.
    would like ti try his .595 roms, nut i'm still not sure how to get to 595.
    besides, liberty upgrades are in the pipeline.
    running gingerbread 602 SBF
    Points: 2,515, Level: 30
    Level completed: 44%, Points required for next Level: 85
    500 Experience Points250 Experience PointsCreated Album pictures7 days registered100 Experience Points
    Slappy's Avatar
    36311
    atlanta
    114
    15 times
    wait for fabs work on .596
    "To be rooted is perhaps the most important and least recognized need of the human soul."
    jarrod138's Avatar
    35466
    12
    I've only used the ones for. 595 . All I did to get to 595 was sbf to 340, flash the 3 .588 files, went to liberty all the way to v5. Then straight to zombie stomped.... took some factory reseting, and what not, but now I seem to be able to swap back and forth between any drew garen roms
    Points: 9,994, Level: 66
    TideFan22's Avatar
    23940
    Florence,Alabama
    3,097
    64 times
    Broodcomb3 is very good
    ZombieStomped with some Seeing Red
    Points: 1,368, Level: 20
    Overall activity: 3.8%
    xjeepguy's Avatar
    31481
    West Virginia
    182
    Quote Originally Posted by TideFan22 View Post
    +1
    jarrod138's Avatar
    35466
    12
    Cool. That's the only one I haven't tried yet....im on foxtrot right now, haven't got to play with it too much yet, but it has the coolest boot animation I've ever freaking seen, being in tanks myself...
    Points: 1,868, Level: 25
    Overall activity: 3.2%
    akeezy's Avatar
    35474
    289
    17 times
    Quote Originally Posted by rudyy View Post
    I think I said something about this on another thread but here it is again. Your safest bet is to backup with titanium backup and sbf to 340 then install 573 gingerbread then 595 over it and then the rom. Then you can restore your apps and settings.
    Back to the best rom. They are all blur free for the most part and seem to all have similar and great battery life. Personally I think the main difference between each is looks. But I've used all his roms and I think broodcomb is the best. Broodcoomb 2 is on a 588 kernel and works well but the 588 kernel has a few bugs and became laggy so I moved to zapx and lexlite on 595. Pretty snappy roms but when broodcomb 3 came out for the 595 build I was possibly the first on it haha. Broodcombs performance may the best of them all and I'm running the beta broodcomb 4 slightly overclocked. Its perfect
    rudyy's Avatar
    30693
    california
    738
    11 times
    you know akeezy, i sbf'd once, and i'm not afraid of it, but it's so time consuming to bring everything back to where it is now. i really don't want to see that finger poking lloyd any time soon again.
    one thing i've learned is to nandroid as soon as i make big changes, and immediately backup new apps.
  1. Drew Garen
    By fersayken2 in forum Gingerbread General Discussion
    Last Post: 05-18-2011, 08:43 PM
  2. Why aren't Drew Garen's ROMs more popular?
    By fc127 in forum Droid X ROMs
    Last Post: 04-01-2011, 12:43 AM
  3. Hi all I am Drew and I am New!!
    By drew823 in forum New Member Introductions & Site Assistance
    Last Post: 08-04-2010, 03:42 PM
best drew garen rom
drew garen
drew garen kernel
drew garen roms motorola droid x
drewgaren
drewgaren rom
drewgaren roms droid x
droid x battery life rom drew garen
droid x zapx ginger 4.3 rom with .595 kernal
droid x zapx ginger 4.3 rom with .596 kernel
