.591 build question
This is a discussion on .591 build question within the Gingerbread Roms forums, part of the Gingerbread Development and Hacking category; I got on the 591 build via liberty toolbox and liberty v5. I want to try lexlite 4.4 and it has a 591 build, but ...
Results 1 to 7 of 7
Thread: .591 build question
    Points: 2,946, Level: 33
    Level completed: 31%, Points required for next Level: 104
    TheJustPull's Avatar
    28826
    580
    .591 build question
    I got on the 591 build via liberty toolbox and liberty v5. I want to try lexlite 4.4 and it has a 591 build, but before I flash it ontop of liberty I want to make sure it is safe to do so, does it matter if its liberty. 591 and not stock 591
    Formerly known as Haywire
    Points: 51,689, Level: 100
    Overall activity: 99.9%
    fezrock's Avatar
    29044
    Asheville-ish
    10,465
    573 times
    It's fine, just wipe data and cache first.
    Everything seems so clear viewed thru the Blu-haze!
    28826
    580
    Give it a shot, he confsued me when I tweeted him and made it.sound like I had to go back to stock. Fingers crossed. Gotta wait another 10% on the battery.
    quinndsm's Avatar
    35953
    Being new to forums I'm sure if there is some sort of rules so here goes. I downloaded the 591 kernel update from the Liberty available roms and now my DX won't get past the Motorola symbol on the reboot. It shuts itself off and comes back to the Motorola symbol again and again. Any ideas?
    quinndsm
    Points: 3,387, Level: 36
    Level completed: 25%, Points required for next Level: 113
    Overall activity: 5.6%
    Snipples007's Avatar
    34930
    New York
    813
    11 times
    Quote Originally Posted by quinndsm View Post
    quinndsm
    Pull battery, hold power and home button, see if the exclamation point cones up. If it does hit search key. try a cache/factory reset. If that doesn't work, or you can't get to that menu then you're going to have to sbf.
    This is a guide on how to sbf.
    http://www.droidxforums.com/forum/droid-x-rs-guides/12015-complete-droid-x-sbf-flashing-guide.html
    Running GingerSnips v. 007
    Points: 5,656, Level: 48
    Level completed: 53%, Points required for next Level: 94
    Overall activity: 1.9%
    500 Experience Points7 days registered250 Experience PointsTagger Second Class100 Experience Points
    hillmom's Avatar
    33775
    Idaho
    685
    19 times
    Quote Originally Posted by Snipples007 View Post
    http://www.droidxforums.com/forum/dr...ing-guide.html
    I'm not needing this now, but I've tried. The screen just goes black. When I eventually let go of the home screen, it just boots normally.
    From my Liberated Gingerbread (v0.5) Droid X
    Constantly Flashing, and Loving it!
    My to-do list is so long, I really shouldn't be here. BACK TO WORK!
    RS Team Leader
    Points: 26,668, Level: 97
    Level completed: 32%, Points required for next Level: 682
    Activity Award
    popcenator's Avatar
    21238
    Omaha, NE
    8,258
    179 times
    You should feel a small vibration in the phone telling you when stock recovery has been initiated.
    GBLDX
  1. build.prop editing question.
    By noXcuse in forum Hacking Help
    Last Post: 04-01-2011, 01:29 PM
  2. [Q] Gala 1.4x on new DX build
    By bennero in forum Droid X ROMs
    Last Post: 11-27-2010, 10:33 AM
  3. Leaked build
    By motohero in forum Droid X General Discussion
    Last Post: 11-23-2010, 11:51 PM
  4. Replies: 0
    Last Post: 09-03-2010, 12:19 PM
  5. QUestion on 2.2 leak build and wi-fi hotspot
    By Enos316 in forum Droid X General Discussion
    Last Post: 08-22-2010, 10:46 PM
.591 kernel update
591 kernel update download
android 2.2 kernel 62.6 v 3.0
download kernel 591 droid x
droid .591 kernel download
droidx .591 kernel
how do i flash and upate kernal for liberty on droid x
liberty gingerbread .591
liberty kernel update download
