gingerbread rom help
This is a discussion on gingerbread rom help within the Gingerbread Roms forums, part of the Gingerbread Development and Hacking category; i finally have the new gingerbread i want to put a rom on it do i do it the same way i did for the ...
Results 1 to 6 of 6
  • 1 Post By djack93
Thread: gingerbread rom help
    djack93's Avatar
    30113
    South Carolina
    62
    i finally have the new gingerbread i want to put a rom on it do i do it the same way i did for the old way like before this update or how do i do it
    cleopete likes this.
    Do what you feel in your heart to be right- for you'll be criticized anyway. You'll be damned if you do, and damned if you don't.
    Points: 6,283, Level: 51
    Level completed: 67%, Points required for next Level: 67
    jmartinez748's Avatar
    23139
    1,191
    87 times
    You can't put the old roms on it (liberty, rubix, apex,ect) but there are a couple that are for gb like blurry bread but yeah its basically the same.the instructions are in the op of the rom
    /l ,[____],
    l---L -OlllllllO-
    ()_)-()_)-o-)_)
    djack93's Avatar
    30113
    South Carolina
    62
    yea i new that .. i want to put a rom on so just pick one and put it on through rom manager
    Points: 5,292, Level: 46
    Level completed: 72%, Points required for next Level: 58
    cleopete's Avatar
    6523
    341
    11 times
    I'm liking the OP just for quoting Eleanor Roosevelt. I never use ROM Manager for much of anything since it doesn't seem to stay very current for a paid app (which appears to be identical to the free version). Bootstrapper is a lot more useful. Initially P3 said to use the D2 Bootstrapper in GB, but several others (including Droid-xer) have since said the DX Bootstrapper will work if you disable USB debugging. Drew Garen's roms can be downloaded and installed through ROM Mgr, in fact that's about the only thing you can do with RM. I used it to dl the rom directly to my phone while on the run, but installed through bootstrapper. Rubix can be found in the stickies, you can probably install via RM but I haven't tried it.
    Rescue Squad
    Points: 28,311, Level: 98
    Level completed: 97%, Points required for next Level: 39
    Leach19m's Avatar
    31277
    Washington
    7,053
    234 times
    Keep in mind, the gb roms currently out were written for the previous leak, not .588
    Points: 9,994, Level: 66
    Overall activity: 1.2%
    TideFan22's Avatar
    23940
    Florence,Alabama
    3,097
    64 times
    Just wait a little while, Gummyjar3.0 GB is in development and will be out shortly
    My phone's named Gunther and he loves Gingerbread, he tells me it makes him run Smoooooth
  1. You can SBF and take Gingerbread OTA
    By DebianDog in forum Gingerbread General Discussion
    Last Post: 04-13-2011, 07:39 PM
  2. OTA gingerbread????
    By tttuning in forum Gingerbread General Discussion
    Last Post: 04-01-2011, 02:16 PM
  3. Gingerbread
    By bobxx in forum Droid X General Discussion
    Last Post: 02-13-2011, 04:58 AM
  4. Gingerbread on the X?
    By turdbogls in forum Droid X ROMs
    Last Post: 12-17-2010, 11:18 PM
  5. Gingerbread?
    By KDLMaj in forum Droid X Hacks
    Last Post: 11-17-2010, 02:53 PM
