Looks like we just got our [EDIT] second [EDIT] gingerbread ROM
UPDATE: THIS ROM IS NOT FOR THE NEWER OTA (588) BUILD, USE ONLY ON THE TBH LEAK OF GINGERBREAD (573)
original post:
rubiX Blurry Bread - Rubik - AllDroid Public Board
This is very basic right now.. don't expect anything fancy for a while.
Initial release:
Full init.d support
Sysctl.Conf support and pre-tweaked
DrodSpeed inside
All apps fully optimized and zipaligned
Zipalign on every boot (for those lazy themers)
Internal Task Killer adjusted
Market apps completely removed (yes, even gmail and google search)
To get full gmail function back, you must set Gmail to sync via accounts/sync settings in the settings app.
To get google search function back, you must download it from the market
To get voice search, voice directions, text to speech back, you must download voice search from the mark
That's all I can remember right now.. Since most people I've had talk to me say they were happy with the new blur, I decided to not include the scripts for adding/removing until I get a little more feedback.
Download link:
http://bit.ly/eELXsT
Mirror attached to the thread.
If you like my work, consider helping me afford my plane ticket to get to Google I/O![]()
https://www.paypal.com/c..._button_id=TYYWQBR78DW7Udrod2169
If you're flashing BlurryBread, wipe data and cache. It probably isn't needed, but do it anyways. I won't support bugs otherwise
4/2/11 9:12 PM
5Likes
{ROOTED/ 591 apex 2.0beta watermarked//OC'ed 1200@66vsel, now the wifes} Tbolt, rooted rommed kernaled, oc'ed 1.4-1.92
