Go from Cyanogenmod 9 to Liberty 3 v2 and correct recovery process?
This is a discussion on Go from Cyanogenmod 9 to Liberty 3 v2 and correct recovery process? within the Gingerbread Help forums, part of the Droid X Gingerbread Forum category; Hi everyone. I'm still rockin my dinosaur Droid X on Page Plus Wireless. I'm on the .605 GB kernal. I was on CM7 Pooka. Now ...
Results 1 to 1 of 1
Thread: Go from Cyanogenmod 9 to Liberty 3 v2 and correct recovery process?
    Points: 1,821, Level: 25
    Level completed: 21%, Points required for next Level: 79
    Oshuaj's Avatar
    27354
    Question Go from Cyanogenmod 9 to Liberty 3 v2 and correct recovery process?
    Hi everyone. I'm still rockin my dinosaur Droid X on Page Plus Wireless. I'm on the .605 GB kernal. I was on CM7 Pooka. Now I'm on CM9 x13thangel. CM9 is cool but I want full functionality back. I would like to install Liberty 3.0 v2 which is a 1st init rom. CM7 and CM9 are both 2nd init so I've been using CWM recovery 2nd init. My question is when do I install the 1st init CWM? After I install Liberty or before? If after, do I use d2 bootstrap or just flash 1st init CWM using Rom Manager once I'm booted into Libery. Or can I just leave the 2nd init CWM alone and use that?
  1. Replies: 7
    Last Post: 06-26-2011, 12:21 AM
  2. Replies: 2
    Last Post: 06-24-2011, 12:48 AM
  3. Going from GB Leak to Liberty process...
    By Buckeye3 in forum Hacking Help
    Last Post: 06-04-2011, 12:48 PM
  4. Liberty 1.5 email process error and sysctl config
    By usmc7356 in forum Droid X ROMs
    Last Post: 02-04-2011, 02:00 AM
  5. Replies: 7
    Last Post: 11-18-2010, 05:11 PM
cm 9 liberty
cyanogenmod 9 htc liberty
cyanogenmod 9 liberty
cyanogenmod 9 password reset
htc liberty recovery image
liberty 3 v2 gapps
liberty 3 v2.0 droid x pageplus
liberty rom droid x
liverty 3 v2 gapps
reset cynogen 9 password
