Hot to go from .604 to .621
This is a discussion on Hot to go from .604 to .621 within the Gingerbread Help forums, part of the Droid X Gingerbread Forum category; So back a couple months ago i took the OTA update to .621.... found out the hard way that you cant root or go back ...
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Hot to go from .604 to .621
    Points: 151, Level: 3
    Level completed: 2%, Points required for next Level: 49
    Overall activity: 2.2%
    VandalDX's Avatar
    60245
    Jul 2012
    8
    So back a couple months ago i took the OTA update to .621.... found out the hard way that you cant root or go back after the update. Well i found a way through the use of linux and was able to go to a version i can root, .604 milestone..... i only did this so i can run miui but miui is too damn buggy. So i decided to go back to regular old .604... Well for the past couple weeks now thats been buggy too. Random restarts, google nav not working etc. So now im trying to go back to my original vanilla droid x... version .621. Problem is that when i tried doing that through RSD lite... it said Failed Flashing process.....
    Note: The sbf i was trying to flash is named -"1FF-p3a_shadow_cdma_shadow-user-2.3.4-4.5.1_57_DX8-51-120111-test-keys-signed-Verizon-US"
    is this the correct sbf i should be using?
    im stuck and dont know what to do know. Can anyone help me with going from .604 milestone to .621 OTA?
    RS Team Leader
    Points: 21,500, Level: 92
    Level completed: 15%, Points required for next Level: 850
    Overall activity: 20.5%
    popcenator's Avatar
    21238
    Omaha, NE
    8,208
    132 times
    Did you extract the SBF file?
    Points: 17,979, Level: 85
    Level completed: 26%, Points required for next Level: 371
    Overall activity: 99.8%
    6,245
    138 times
    Try using a different SBF file https://sites.google.com/site/motosbf/droid-x-sbf-files , make sure the file isn't corrupt. Also make sure your drivers are up to date, and maybe try a different version of RSD Lite. Lastly make sure you are using the cable that came with your phone. See if any of that helps.
    VandalDX's Avatar
    60245
    Jul 2012
    8
    Yes, I extracted the SBF. And is it a "must" yo have the original cable? Because I lost that bad boy a year ago
    Sent from my Milestone X using Tapatalk 2
    6,245
    138 times
    It's not a must, but it is highly recommended. A lot of people have issues with a cable that isn't the original one. The one you have now is it at least a Motorola cable or just a regular knock off?
    Edit: i just want to make sure of something. Your droid x, is it through Verizon or are you a milestone all the time?
    VandalDX's Avatar
    60245
    Jul 2012
    8
    i got the verizono droid x. no the milestone. i had to go to milestone sbf for root access
    6,245
    138 times
    Rsd lite has been known to work only when it wants to. Try flashing it again. Before you do, make sure you have the latest drivers installed on your computer and if it still doesn't work try a different version of rsd. Worse comes to worst you could try the .604 iso disc.
    VandalDX's Avatar
    60245
    Jul 2012
    8
    problem solved. DROID x back on. 621
    I got rsd lite 5.7 and the 621 sbf from that site. And it worked
    Points: 3,108, Level: 34
    Overall activity: 5.0%
    newmanx4's Avatar
    34469
    703
    27 times
    This thread is a great example of how finicky RSD Lite can be. With my XP and Vista computers I run 5.4.4 with no problems. But with Win 7 64 bit 5.7 is the only one that works with it. I hold out hope for a .621 ISO so we can leave RSD in our rear view.
    Sent from my Black Iced X
.604 iso cd fails
.604 ota update
.604 to .621
.604 to go from .621 update
604 to 621 update
droid x how to go back .604
how to get from .604 to ota .621
how to install .621 from .604
how to update to .621 from .604
where to go from droid x 604
