Problems with Milestone X on GB .602
This is a discussion on Problems with Milestone X on GB .602 within the Gingerbread Help forums, part of the Droid X Gingerbread Forum category; Hi all. I got my x onto GB.602 using linux and stayed on the .00R basebandand. Excitedly, I ran several roms. In the beginning everything ...
Thread: Problems with Milestone X on GB .602
    Points: 489, Level: 9
    Level completed: 78%, Points required for next Level: 11
    Overall activity: 0.6%
    jmkoep's Avatar
    44875
    Aug 2011
    Fairbanks, AK
    29
    Hi all. I got my x onto GB.602 using linux and stayed on the .00R basebandand. Excitedly, I ran several roms. In the beginning everything was going good until a couple of days ago when I flashed SSX 2.2. I started getting "process.android.phone" force closes and could no longer send or receive calls and my data connection became flaky. I figured SSX just didn't play well with my phone (This happened once on the Apex RC4). I flashed to the latest CM7, yet alas, the problem persisted. I then tried OMFG, Liberty 3. I SBF'd back to .602 and tried to go from a clean phone (even wiped sd card just because), I no longer got the FC, but my data connections were still sluggish or wouldn't connect. I find it strange since they had all seemed to work previously.
    I flashed back to .340 this morning and everything seems okay. Data isn't zippy, but I think it is running at normal levels. I did have my phone say my baseband was unavilable - but reflashed and it showed up again.
    So am I screwed when it comes to the latest .602 roms now if I don't have the .13p baseband? I wouldn't think it would affect the Roms on a functional level, but perhaps I am mistaken. Now that I am back on .340 I find Froyo lacking.
    Thanks!!
    milestone x i have to with Alltel... i cant get the phone phone to install a rom...
    milestone x i have to with Alltel... i cant get the phone to install a rom... what rom to use that will work with the phone??? and do you know the process on doing the right way??? PLZ HELP...
    if i have to give you my phone number i will... just so you can tell me hands on...
    Points: 4,842, Level: 44
    Level completed: 46%, Points required for next Level: 108
    RavenSoft's Avatar
    24838
    168
    Points: 5,393, Level: 47
    Level completed: 22%, Points required for next Level: 157
    Overall activity: 0.7%
    chuck54's Avatar
    41016
    697
    Sorry everybody, i have been out of the loop of the droidx world and i need to find an fxz file for .605. iv searched for about an hour and im kind of in a hurry. can anyone direct me to the file? i can't use the linux method, my laptop's screen is broke, and i need a monitor to see anything... thank you for the help!!
    I'm diagnosed with a severe case of noobecidis, it might not be treatable...
  1. Milestone X Data Problems!
    By Anchorth in forum Droid X Stock Issues
    Last Post: 11-09-2011, 04:50 AM
  2. Milestone X help please!
    By Jemccall in forum Milestone X Hacks
    Last Post: 10-28-2011, 01:01 PM
  3. .SBF on milestone x
    By grizzbud in forum Droid X Rescue Squad
    Last Post: 10-05-2011, 01:40 PM
  4. Is it possible to get GB .602 on Milestone X?
    By jmkoep in forum Milestone X Hacks
    Last Post: 09-26-2011, 12:24 PM
  5. New(?) Milestone rom
    By fezrock in forum Milestone X Hacks
    Last Post: 08-10-2011, 03:43 PM
flashing liberty on milestone x
install liberty on milestone x
liberty 3 from milestone rom
liberty 3 rom from milestone
liberty milestone x
liberty3 milestone x
milestone x gingerbread roms
milestone x problems
milestone x roms
roms that will run on gingerbread milestone x
