Market problems. Found the cause, need a solution
This is a discussion on Market problems. Found the cause, need a solution within the Gingerbread Help forums, part of the Droid X Gingerbread Forum category; This is my first post even though I've lurked around for a long time. Anyway, I've had the same problems with the market that many ...
Thread: Market problems. Found the cause, need a solution
    Points: 379, Level: 7
    Level completed: 58%, Points required for next Level: 21
    mrclean81's Avatar
    47617
    Sep 2011
    This is my first post even though I've lurked around for a long time. Anyway, I've had the same problems with the market that many others have had. I can't download or update apps after the 602 update. All I get is the orange triangle and the download stops. I've had no luck in searching forums or calling Verison. Today I uninstalled the market update and went back to the old version. The same thing happened, but this time it said "download paused, waiting for wifi". I was at a hotel last weekend and the market worked as long as I was connected to their wifi, so that tells me that either I have something set up wrong, or the update took it upon itself to only let me download apps while on wifi. I never had this problem until the update, and I've been through every setting I can think of. Any ideas?
    mrclean81's Avatar
    47617
    Sep 2011
    Ok I got some help over at XDA and wanted to post the solution for anyone else having this problem. Go to settings, battery and data manager, go to data saver and uncheck the data saver box. Its that simple
    RS Team Leader
    Points: 21,598, Level: 92
    Level completed: 25%, Points required for next Level: 752
    Overall activity: 14.6%
    popcenator's Avatar
    21238
    Omaha, NE
    8,215
    132 times
    Go into settings and make sure data saver isn't on.
    Edit: Ninjad by the OP, nice work!
    mrclean81's Avatar
    47617
    Sep 2011
    We must have posted that at the same time. Thank you for the reply though. I cant believe I couldnt figure this out, but glad there are sites like this and XDA out there to help when I cant
  1. Replies: 2624
    Last Post: 04-24-2013, 07:11 PM
  2. Replies: 4
    Last Post: 09-05-2011, 05:31 PM
  3. HBO Go not found on Market?
    By Jedi Beavis in forum Droid X Apps
    Last Post: 07-20-2011, 11:52 AM
  4. Linux solution to your Windows/RSD lite problems
    By 1KDS in forum Droid X Hacks
    Last Post: 06-17-2011, 06:45 PM
  5. Possible solution to my reception problems at home?
    By DroidXGonGiveItToYa in forum Droid X Hacks
    Last Post: 12-19-2010, 04:44 PM
android market orange triangle
android waiting for wifi
can cause difficulties in getting into the market
droid x waiting for wifi
orange triangle android market
orange triangle droid 3
orange triangle when downloading apps
waiting for wifi droid x
what can cause difficulties in getting into the market
