bootstrap
This is a discussion on bootstrap within the Gingerbread Help forums, part of the Droid X Gingerbread Forum category; This might be a dumb question, but if I need d2 bootstrap to install gb, how do I save the apk onto my sd card, ...
Thread: bootstrap
    Points: 2,189, Level: 28
    Level completed: 26%, Points required for next Level: 111
    Overall activity: 4.7%
    fnmetal's Avatar
    35394
    new haven CT
    668
    15 times
    bootstrap
    This might be a dumb question, but if I need d2 bootstrap to install gb, how do I save the apk onto my sd card, and can I even get d2 bootstrap from the market if I have dx installed? Help please
    with Google ™
    Points: 1,016, Level: 17
    abinkley's Avatar
    27341
    57
    You can have both installed. And I use MyBackup Pro. In the reware folder it creates on your sd card during apk+data backup, you can find the program. I usually move that, ROM Manager and Mybackup pro apks into a dedicated folder for when I change roms and want quick and easy access.
    fnmetal's Avatar
    35394
    new haven CT
    668
    15 times
    Ive been backing up everything with tibu .. and it creates data and a tar.gz of the app, do you know if I can just copy it from /system/app onto the sdcard somewhere? Thanks for your help.
    with Google ™
    Points: 4,487, Level: 42
    Level completed: 69%, Points required for next Level: 63
    Overall activity: 1.2%
    rudyy's Avatar
    30693
    california
    738
    11 times
    not sure what you mean, but d2 bootstrap can be on your phone at the same time as dx. download it like any other app and launch, as needed.
    use it to make system backups, to flash roms, themes and other zips, as needed, and to restore to a previous condition, as needed.
    also to wipe caches and data, s needed.
    running gingerbread 602 SBF
    fnmetal's Avatar
    35394
    new haven CT
    668
    15 times
    Quote Originally Posted by rudyy View Post
    I mean can I copy d2 bootstrap from /data/app onto my sdcard so I have it ready to go once I sbf? Apologies for the vague question should have just said that to begin with.
    Last edited by fnmetal; 06-01-2011 at 09:18 PM. Reason: realized its in data not system/app :-p
    with Google ™
  1. ? about bootstrap
    By shawn in forum Droid X Hacks
    Last Post: 02-10-2011, 06:24 PM
  2. Help with bootstrap
    By t.crawford714 in forum Droid X Help
    Last Post: 02-01-2011, 09:28 PM
  3. Bootstrap
    By mrclean2828 in forum Droid X Rooted Issues
    Last Post: 12-10-2010, 09:55 AM
bootstrap d2 apk
copy d2 boostrap to sd
d2 bootstrap apk
d2 bootstrap apk download
d2 bootstrap apk for droid x
d2 bootstrap for droid x apk
d2 bootstrap.apk
d2 bootstrapper apk
droid x bootstrap apk
droid x d2bootstrapper.apk
droid x download bootstrap d2 apk
dx bootstrap apk
dxbootstrap.apk
facebook desktop site
getjar apk
