How would i go from 4.4.595 running broodcomb to foxtrot on my sd
This is a discussion on How would i go from 4.4.595 running broodcomb to foxtrot on my sd within the Gingerbread Help forums, part of the Droid X Gingerbread Forum category; I wanna keep apps bit wnna try out foxtrot rom i have downloaded on my sd....wnna do it safely. Sent from my DROIDX using Droid ...
Thread: How would i go from 4.4.595 running broodcomb to foxtrot on my sd
    31 days registered250 Experience Points7 days registered100 Experience Points
    vrt420's Avatar
    36692
    61
    Points: 1,868, Level: 25
    Overall activity: 3.2%
    akeezy's Avatar
    35474
    289
    17 times
    That's no problem at all. I only use drew garen roms and switch easily between them.
    First make sure you make a nandroid backup before each switch just to be safe. Then in clockwork recovery wipe cache before installing the foxtrot zip. Then reboot when finished.
    Your apps and settings should all be there. One problem I had though when I was trying these new roms is that launcherpro would continuously force close and it was my default so I had to sbf. Make sure you test out your launcher before making it the default
    Points: 2,946, Level: 33
    Level completed: 31%, Points required for next Level: 104
    TheJustPull's Avatar
    28826
    580
    Make sure your running the right build of gb for the specific rom or you'll have boot loops when you try downloads from the market that will require an sbf to fix. I learned the hard way.
    Formerly known as Haywire
    akeezy's Avatar
    35474
    289
    17 times
    Word to that. I just posted on Lexlite thread about that
  1. apex or broodcomb?
    By zlittell in forum Gingerbread Roms
    Last Post: 05-02-2011, 09:42 AM
  2. Anybody tried Drewgaren's BROODCOMB rom?
    By lynneddington in forum Gingerbread Roms
    Last Post: 04-28-2011, 12:15 AM
  3. Replies: 832
    Last Post: 04-24-2011, 09:14 PM
  4. Running app
    By beachy in forum Droid X Apps
    Last Post: 01-11-2011, 10:20 PM
  5. Running hot
    By boston0108 in forum Droid X Help
    Last Post: 12-12-2010, 07:15 PM
broodcomb 4 .595
broodcomb vs foxtrot
foxtrot rom will allow restart in recovery
foxtrot ultima
foxtrot ultima 1 keeps rebooting
foxtrot ultima 1 rom
how to install foxtrot ultima on droid x
installing foxtrot droid x
