Pretty annoying facebook contacts problem !
This is a discussion on Pretty annoying facebook contacts problem ! within the Gingerbread Help forums, part of the Droid X Gingerbread Forum category; Ok so when i synced my facebook with my contacts it places a +1 in front of all the numbers so when i go into ...
Thread: Pretty annoying facebook contacts problem !
    Points: 4,309, Level: 41
    Level completed: 80%, Points required for next Level: 41
    Overall activity: 3.2%
    250 Experience Points7 days registered100 Experience PointsCreated Album picturesTagger Second Class
    dschwartz0815's Avatar
    35743
    Ohio
    656
    Exclamation Pretty annoying facebook contacts problem !
    Ok so when i synced my facebook with my contacts it places a +1 in front of all the numbers so when i go into GOsms Pro and put some ones name in it doesn't recognize the name to a number for some reason. But if i make a new contact with there name and number with out the +1 it works fine. But there is no way to edit the contacts because they are from facebook! Please help, Thanks in advanced
    Points: 711, Level: 14
    Level completed: 11%, Points required for next Level: 89
    GlowinSmurff's Avatar
    23314
    Minnesota, USA
    32
    this happens on the stock app on .558 Gingerbread as well, it makes SMS unable to send, seems to happen randomly. usually retyping the number w/o the areacode (if same as yours) will solve it. perhaps after the initial sync turn off FB contact sync?
    Points: 43, Level: 1
    Level completed: 86%, Points required for next Level: 7
    erinonline's Avatar
    49113
    Oct 2011
    I know this is an old thread, but it is my exact problem. I tried 'unlinking' the contacts from Facebook, but still they show the '+1'. The phone won't let me edit the #. When I type the phone # manually, it goes through just fine. I'm sure hoping there's some workaround...this is a pain! And, as mentioned above, just started randomly (as far as I can tell). I did battery pull and *228 as well. Any suggestions?
  1. Facebook help.....pretty please....
    By UDLOSE in forum Droid X Apps
    Last Post: 01-27-2011, 10:13 AM
  2. Facebook Pics and Contacts problem solved
    By gm54 in forum Droid X General Discussion
    Last Post: 12-11-2010, 12:19 PM
  3. Problem with facebook/contacts list
    By awdxtc in forum Droid X Help
    Last Post: 11-30-2010, 08:36 PM
  4. Problem with facebook contacts
    By B0SSH0GG89 in forum Droid X General Discussion
    Last Post: 11-29-2010, 11:07 PM
  5. Problem deleting contacts that happen to be facebook friends
    By jake1086 in forum Droid X General Discussion
    Last Post: 10-22-2010, 09:44 PM
1 in front of facebook contacts
1 in front of facebook contacts android
android facebook contacts 1
droid x facebook numbers
facebook contacts 1
facebook contacts with 1
gingerbread sync facebook
how to resync facebook contacts on droid x
link contacts on droid x
