news and weather widget
This is a discussion on news and weather widget within the Gingerbread Help forums, part of the Droid X Gingerbread Forum category; back on froyo as well as gb 4.5.73 I had a google provided (?) widget/app listed as news and weather. it had multiple side scrolling ...
Results 1 to 7 of 7
Thread: news and weather widget
    Points: 5,591, Level: 48
    Level completed: 21%, Points required for next Level: 159
    zoe's Avatar
    9237
    lost angels
    1,429
    33 times
    back on froyo as well as gb 4.5.73 I had a google provided (?) widget/app listed as news and weather. it had multiple side scrolling screens, first was weather and then followed by selected news provider/category feeds.
    notes on the latest deodexed gb 4.5.88, I no longer have it. right after flashing the latest gb the widget said it couldn't load, so I guess it's not readily available in this leak version.
    before I try to see if I can rip it from a nandroid back up, any one able to send it my way?
    feeling a bit uninformed...
    zoe's Avatar
    9237
    lost angels
    1,429
    33 times
    ok, so once I figured out the actual .apk name I was able to grab a copy from here
    http://www.chadhaney.com/droidXDefault/
    installed, restored data from tibu and alls good again
    ereh seog erutangis
    Points: 704, Level: 14
    Level completed: 4%, Points required for next Level: 96
    Overall activity: 0.6%
    bophead's Avatar
    35561
    63
    Hi
    I downloaded the apk for the news and the apk for the weather. The news is post gb and not what I am looking for. The original news and weather widget seems to be missing with the 588 odexed. This news widget is a updated one, though I prefer the older version better. Any way of getting the old version onto GB.
    Here is a link that shows the original widget.
    Android 2.1 Google News/Weather widget available for download.
    The fixed it and it wasn't broke. I like the old much better.
    bophead's Avatar
    35561
    63
    I just tried using the file from XDA and it doesn't work either. It FCs which you try to use it.
    Points: 7,190, Level: 56
    Level completed: 20%, Points required for next Level: 160
    Overall activity: 1.2%
    bsbabcock's Avatar
    16420
    1,342
    96 times
    Interesting.. I'm on ApeX Alpha 2 GB and there she is.. The old Genie (News and Weather) widget. Running it now actually. What's nice is the app runs as an app as well as a widget. Don't know how it is on battery consumption but it's simple and gets it done. I wish Pulse would consider a simpler widget like that actually. As much as I love the Pulse app, the widgets are a little busy if you're trying to keep the home screens a bit more minimal.
    I need two DX's.. One to try rom's on and one for MIUI because it's THE daily driver for me so I'm not messin' with it.
    zoe's Avatar
    9237
    lost angels
    1,429
    33 times
    Quote Originally Posted by bophead View Post
    the one I used on latest gb leak was from the site I posted above called genie.apk
    I did get admonished in another thread for suggesting to someone else to use an old .apk on a new os, but it works without issue for me and as this is a google written app I believe it has a bit more flexibility than other 3rd party apps
    I got force closes the first time using it, a reboot solved it
    ereh seog erutangis
    zoe's Avatar
    9237
    lost angels
    1,429
    33 times
    Quote Originally Posted by bsbabcock View Post
    I especially like the weather bit with the scrollable timeline. I've always used it and set the update frequency to like 6 hrs or so, my battery life has been unaffected by this afaik, other things are more of an issue regarding battery. at home I use wifi all day (live in a canyon), but I get at least 16 --> 24+ hrs with heavy --> moderate use on latest gb deodexed. some days my screen is on for 4+ hrs if I can't put the thing down
    ereh seog erutangis
  1. Genie Widget (News and Weather)
    By baniels in forum Droid X Apps
    Last Post: 11-12-2011, 03:17 AM
  2. Rubix Blurry 2.0.. weather widget and news widget??
    By HHARRIS in forum Droid X ROMs
    Last Post: 04-16-2011, 03:47 AM
  3. Accu weather factory weather widget issue
    By silver04v in forum Droid X Help
    Last Post: 02-17-2011, 09:27 PM
  4. Replies: 20
    Last Post: 11-14-2010, 06:41 PM
  5. Replies: 0
    Last Post: 08-02-2010, 01:40 PM
download google news and weather widget
gingerbread news and weather apk
gingerbread news and weather widget
gingerbread news and weather widget apk
gingerbread widgets apk
google news and weather apk
google news and weather app download
google news and weather app for android download
google news and weather widget download
google news weather widget download
