Sysctl on GB
This is a discussion on Sysctl on GB within the Gingerbread Help forums, part of the Droid X Gingerbread Forum category; I have copied the sysctl file from gb to my laptop and wanted to edit it. My (probably dumb) question is: What program do I ...
Results 1 to 6 of 6
Thread: Sysctl on GB
    Points: 9,494, Level: 65
    Level completed: 48%, Points required for next Level: 156
    skennelly's Avatar
    17443
    Illinois
    1,319
    44 times
    Sysctl on GB
    I have copied the sysctl file from gb to my laptop and wanted to edit it. My (probably dumb) question is: What program do I need to open this file in order to edit it?
    Sent from my DROID X in Western Illinois
    skennelly's Avatar
    17443
    Illinois
    1,319
    44 times
    Or, does anyone know if jrummy's sysctl app in the market works on gb?
    Points: 5,992, Level: 50
    JNEHAMA's Avatar
    28370
    Long Island New York
    1,205
    65 times
    I used his universal zip v6.1.3 on stock rooted deodexed gingerbread and my phone ran smoothly. I got the zip from his imoseyon blog. I just flashed rubix blurry bread so am not using it now because Drod2169 has incorporated his own tweaks so I will see in the next few days which functions best for me. The rom is pretty much just init d support and internal tweaks that Drod made there are no visual changes, and I have to tell you my free memory runs much lower on the rom so I'm a bit anxious, but Drod usually know what he's doing. In terms of making your own tweaks you can probably just make changes using root explorer read/write text editor. In Rubix the systctl.conf is in etc, its probably the same in stock.
    Also you can tweak the parameters using jrummy's overclock app. Look in the settings, advanced.
    skennelly's Avatar
    17443
    Illinois
    1,319
    44 times
    Thanks for the reply. I am also on blurrybread, sorry I forgot to mention that.
    I tried to open the file w/the text editor in root explorer however, when it opens it is just a bunch of weird symbols. I assumed that the file was too large for the txt editor, which is why I was trying to alter it on my laptop. However, the txt editor program I have does the same thing that the phone does. Is there a program you might recommend for me?
    Points: 1,276, Level: 19
    Level completed: 76%, Points required for next Level: 24
    balldope's Avatar
    26596
    New Jersey
    124
    You need to open sysctl.conf not sysctl. Sysctl is a binary file the .conf is a text file.
    ** Droid X Rooted - GB - Custom Theme **
    skennelly's Avatar
    17443
    Illinois
    1,319
    44 times
    ahhh, thank you.
  1. [Tutorial] ROMs & Sysctl.conf & other tweaks!
    By macpro88 in forum Droid X Hacks
    Last Post: 05-28-2012, 08:55 PM
  2. Sysctl in liberty rom
    By TheJustPull in forum Droid X ROMs
    Last Post: 04-08-2011, 09:18 PM
  3. minfreemanager & sysctl config
    By skennelly in forum Hacking Help
    Last Post: 03-04-2011, 02:45 PM
  4. Sysctl Hack and rooted stock
    By Xersized in forum Droid X Hacks
    Last Post: 02-23-2011, 12:46 PM
  5. Sysctl settings
    By patrick72 in forum Droid X General Discussion
    Last Post: 02-16-2011, 02:40 PM
android gingerbread conf sysctl
android sysctl.conf bionic
droid x gingerbread sysctl config
gingerbread sysctl
sysctl settings
sysctl settings on gingerbread
sysctl settings root tools
sysctl.conf best
sysctl.conf for gingerbread
sysctl.conf gingerbread
