Google Navigation Way off !
This is a discussion on Google Navigation Way off ! within the Gingerbread Help forums, part of the Droid X Gingerbread Forum category; Seems With GB, either it takes FOREVER to locate me and when it does " Find" me... Its several hundred feet off and going the ...
Results 1 to 9 of 9
Thread: Google Navigation Way off !
    jackelbait's Avatar
    10869
    Glen Burnie, MD
    98
    Seems With GB, either it takes FOREVER to locate me and when it does " Find" me... Its several hundred feet off and going the wrong way lol...
    Discovered this while walking in DC attempting to see all the Statues....
    Anyone else have this problem ?
    And there is no HUGE circle where my location is.. It has me "Pinpointed" but its off..
    Points: 1,302, Level: 20
    Level completed: 2%, Points required for next Level: 98
    Milkweed25's Avatar
    34576
    93
    Quote Originally Posted by jackelbait View Post
    I have the same problem.
    Points: 965, Level: 16
    Level completed: 65%, Points required for next Level: 35
    berserker's Avatar
    34718
    Maryland
    25
    Stock GB and nav is spot on for me.
    Xponentially Better
    Guest Xponentially Better's Avatar
    Probly just your phone. Mine worjs very well. Down to steps measurements.
    turdbogls's Avatar
    21278
    O-Town FL
    147
    7 times
    was spot on for me as well. once i had to reboot the phone for it to find me, but after that it was spot on. haven't tried nav on the new 588 build tho.
    Points: 1,532, Level: 22
    Level completed: 32%, Points required for next Level: 68
    Overall activity: 0.6%
    crunkfrunk's Avatar
    15286
    Columbus, Ohio
    171
    7 times
    I have the same problem with .588, it worked fine on the leak IIRC but now it won't even find my location accurately
    Themer
    Points: 44,019, Level: 100
    Overall activity: 8.8%
    Downloads
    Wulf's Avatar
    33106
    2,435
    77 times
    It works for me, only minor issue I have is when the pointer points west when facing east, and points east when facing west. North and south point correctly. The location is accurate and no problem with navigation.
    Deodexed Ginger Man is juiced up and ready for action.....
    You can checkout all my themes here
    http://www.mydroidworld.com/forums/wulf-droid-x-themes/
    crunkfrunk's Avatar
    15286
    Columbus, Ohio
    171
    7 times
    I cleared the data for maps and that seemed to fix the problem of not finding my location, after it was spot on but I haven't tried navigation yet
    Points: 2,703, Level: 31
    Level completed: 69%, Points required for next Level: 47
    qdtphotog's Avatar
    12821
    Fairfax, VA
    160
    Quote Originally Posted by crunkfrunk View Post
    How do you clear the data for maps? I've just started to have the same problems with navigation and gps. It took forever to search for gps even though I was outside under the clear blue sky. Then it kept thinking I was not on the right road so it kept trying to reroute me. Thanks.
  1. Google navigation issue
    By albokay in forum Droid X Apps
    Last Post: 01-14-2011, 08:59 PM
  2. Rubix and google navigation not working
    By cjacobs in forum Droid X Help
    Last Post: 12-31-2010, 01:12 PM
  3. Google Navigation freezes during route
    By DirtyBirdNJ in forum Droid X Help
    Last Post: 09-22-2010, 08:29 AM
  4. Google Navigation Voice
    By mschneid in forum Droid X Help
    Last Post: 08-05-2010, 05:02 PM
  5. Google Navigation Volume Control
    By floydiannyc in forum Droid X Help
    Last Post: 07-22-2010, 06:05 PM
android navigation wrong directions
droid navigation wrong location
google navigation inaccurate
google navigation is off
google navigation is way off
google navigation location is off
google navigation location off
google navigation problems droid
navigation not finding my location
