BootLoop After Rooted Gingerbread Install
This is a discussion on BootLoop After Rooted Gingerbread Install within the Gingerbread Help forums, part of the Droid X Gingerbread Forum category; I am running Liberty 1.5 and I thought I'd try the new rooted Gingerbread zip. I had not installed the stock version yet so I ...
Thread: BootLoop After Rooted Gingerbread Install
    I am running Liberty 1.5 and I thought I'd try the new rooted Gingerbread zip. I had not installed the stock version yet so I just flashed the zip file. Now I can't get out of bootloop. I tried the Power+Home and it takes me to the exclamation in the triangle above the droid but hitting the search key does not take me to the bootstrap menu. What can I try next??
    Points: 9,994, Level: 66
    Overall activity: 1.2%
    TideFan22's Avatar
    23940
    Florence,Alabama
    3,097
    64 times
    You have to hit both volume buttons instead of search button. Then when u select factory reset u hit power button instead of camera button. Its stock recovery not bootstrap
    KornShukka
    Points: 1,290, Level: 19
    Level completed: 90%, Points required for next Level: 10
    1 year registered3 months registered31 days registered7 days registered100 Experience Points
    gclo85's Avatar
    31533
    State College, PA
    45
    I don't know why but I just had the same problem and what I did was just kept holding down the power button and the home key even when it kept rebooting and it eventually it worked and I got into my phone.
    Thanks TideFan22.....You're a lifesaver!
    TideFan22's Avatar
    23940
    Florence,Alabama
    3,097
    64 times
    Glad u got it worked out man. Now enjoy it
    KornShukka
  1. Flashing Rooted Gingerbread
    By gclo85 in forum Everything about Gingerbread
    Last Post: 03-29-2011, 09:52 PM
  2. Gingerbread/ non rooted
    By bobxx in forum Everything about Gingerbread
    Last Post: 03-28-2011, 10:06 PM
  3. liberty 1.5 bootloop--first install
    By whataberger in forum Droid X Rooted Issues
    Last Post: 03-16-2011, 06:50 PM
  4. Rooted Froyo OTA vs Gingerbread
    By droidXchick in forum Everything about Gingerbread
    Last Post: 11-08-2010, 01:57 PM
  5. Replies: 3
    Last Post: 11-06-2010, 08:25 AM
bootloop after liberty install on droid x
droid x boot loop after gingerbread
droid x gingerbread bootloop
gingerbread boot loop after after install
