Odex to Deodex in GB
This is a discussion on Odex to Deodex in GB within the Gingerbread General Discussion forums, part of the Droid X Gingerbread Forum category; Hi All, Just flashed gb from froyo. Thanks to all for the great posts. My question is now that I have an odex GB what ...
Results 1 to 6 of 6
Thread: Odex to Deodex in GB
    Points: 1,116, Level: 18
    pharmnatr's Avatar
    29462
    144
    Hi All,
    My question is now that I have an odex GB what is the procedure to flash deodex gb with the ultimate goal of trying liberty. The Official DX Gingerbread 2.3.3 (4.5.596) Release Thread - Something for everyone says to - "Download the zip ,Reboot phone into Clockwork Recovery
    Install the Zip file."
    Do I need to wipe data / factory reset, clear cache or do I just flash it on top of my odex version? I assume I should make a nandroid backup just in case!
    TIA
    AL
    Moderator
    Points: 25,450, Level: 96
    Frequent Poster
    mikeinrichmond's Avatar
    9010
    Richmond, Va
    7,668
    392 times
    Yes make a backup, but you don't need to wipe anything, just flash it over top in clockwork...
    pharmnatr's Avatar
    29462
    144
    Thank you,
    Also, do I need to go to a deodex version to get to Apex 2.0 or can I skip the deodex and go directly to Apex. Eventually I would like to add some themes to Apex
    Al
    jline123's Avatar
    42390
    Jul 2011
    44
    I'm wondering the same thing, I had a leaked and rooted version of GB, went to p3droids page and flashed the odexed zip right on top. After 5+ attempts at deodexing myself, I gave up. So what do I need to do to get odexed: can I just flash the deodexed version right over the odexed version or do I need to sbf back to group, root, then flash? I've deleted bloatware and I think that might be the issue. And if I do nothing, will my phone be okay have went halfway through the deodexing process?
    Points: 3,516, Level: 37
    Level completed: 11%, Points required for next Level: 134
    Overall activity: 3.5%
    NUNsLAUGHTER92's Avatar
    38861
    Las Vegas, NV
    464
    8 times
    Quote Originally Posted by pharmnatr View Post
    Thank you,
    Al
    You shouldn't have to flash a deodexed version. When you install apex you're going to be overwriting your current system, everything in it. But I'd wipe data, dalvic and cache before installing it.
    "The road to hell is paved with good intentions"
    Shaun's Avatar
    20611
    65
    Quote Originally Posted by NUNsLAUGHTER92 View Post
    +1 for this advice, exactly what I did when LibertyGb came out and worked flawlessly! No need to deodex unless you just want to theme with stock .596 (rooted of coarse!)
  1. .595 deodex over .595 odex???
    By thearchiexdm32 in forum Gingerbread General Discussion
    Last Post: 05-20-2011, 12:23 PM
  2. Need lil gb deodex help
    By Anubisyn in forum Gingerbread Help
    Last Post: 05-02-2011, 04:00 PM
  3. do i need to deodex?
    By jfederice in forum Droid X ROMs
    Last Post: 12-13-2010, 09:30 AM
  4. New easy deodex/odex by our own 928Droid
    By Garemlin in forum Droid X Hacks
    Last Post: 12-07-2010, 05:13 PM
  5. Odex vs deodex...a noob question
    By HarleyDad in forum Droid X Hacks
    Last Post: 11-18-2010, 08:19 AM
deodex
deodex droid x
deodex vs odex
flash deodex over odex
flashing deodexed over odexed
how to deodex
how to deodex android gingerbread
how+to deodex
odex gb.zip
odex vs deodex
