.595 leak battery problem
This is a discussion on .595 leak battery problem within the Gingerbread General Discussion forums, part of the Droid X Gingerbread Forum category; Correction: settings does not give % spare parts does. My bad. Of course foxtrot. 595 deodexed...
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: .595 leak battery problem
    patrick72's Avatar
    22485
    55
    Points: 1,868, Level: 25
    Overall activity: 3.2%
    akeezy's Avatar
    35474
    289
    17 times
    Yea these drew garen roms on the 595 build show 20% battery increments.
    patrick72's Avatar
    22485
    55
    Thanks akeezy. I love foxtrot so far. No fc. And just great speed, without oc
    Points: 567, Level: 11
    Level completed: 34%, Points required for next Level: 33
    Overall activity: 0.7%
    cbmgg.'s Avatar
    33784
    37
    I had the same thing happen to me except my phone would not charge past 90% on a 3 hour charge (left it plugged in longer just to make sure). I did a battery pull and it fixed the problem.
    akeezy's Avatar
    35474
    289
    17 times
    Quote Originally Posted by patrick72 View Post
    I'm glad you like it. I love drew's roms. I installed foxtrot and on the initial boot i set launcherpro as my default home and it continuously force closed on me for some reason and i couldn't do anything else because it just kept showing the force close popup and I had to sbf. But I'm glad its working out for you.
    Now that i think about it, i probably should just have pulled out the battery and booted into clockwork and reinstalled it. dammit. haha
  1. Battery percentage in toolbar for .595 leak?
    By Womp in forum Gingerbread Development and Hacking
    Last Post: 05-12-2011, 10:25 PM
  2. Battery problem
    By rimik in forum Droid X Help
    Last Post: 04-16-2011, 11:34 AM
  3. Rubix focused 1.9.0 for leak and non leak versions out1
    By theidoctor in forum Droid X ROMs
    Last Post: 12-07-2010, 10:36 AM
  4. Battery problem?
    By Mudig in forum Droid X Help
    Last Post: 10-16-2010, 01:23 PM
  5. My Droid X definitely has a battery or battery hog problem... Screenshots Inside
    By Talldarknfugly in forum Droid X General Discussion
    Last Post: 08-03-2010, 11:44 AM
droid x battery expanding
droid x battery indicator not accurate
gingerbread battery meter issues
