GB - Tips/Tricks/Better Battery Life/And Everything Else!
This is a discussion on GB - Tips/Tricks/Better Battery Life/And Everything Else! within the Gingerbread General Discussion forums, part of the Droid X Gingerbread Forum category; Hooray! Gingerbread is finally here for the Droid X! Featuring Motorola's new Blur system! GingerBlur! Below and in the next few posts will be the ...
Page 1 of 13 12311 ... LastLast
Results 1 to 10 of 128
Like Tree24Likes
Thread: GB - Tips/Tricks/Better Battery Life/And Everything Else!
    Points: 49,198, Level: 100
    Overall activity: 3.0%
    macpro88's Avatar
    20491
    6,938
    320 times
    Post GB - Tips/Tricks/Better Battery Life/And Everything Else!
    Hooray! Gingerbread is finally here for the Droid X! Featuring Motorola's new Blur system! GingerBlur! Below and in the next few posts will be the key feature highlights of the new GingerBlur, hope you enjoy!
    Improved Home Launcher
    Motorola's new "GingerBlur" (Cross between Gingerbread and Motorola's Blur) features a new home launcher with a much improved app drawer that now features app groups.
    Hit the app drawer button in the bottom right corner. When the app drawer opens up, tap "All Apps" in the top left corner to create new groups and navigate between them. A Market shortcut has also been added in the top right corner!
    Improved text selection and now with cut, copy, and paste!
    Now that we have Gingerbread, we can now cut, copy, and paste text selection! Simply long-press in the text field to bring up the menu! You will also notice little "handlebars" when moving the cursor around to select text.
    macpro88's Avatar
    20491
    6,938
    320 times
    More account choices!
    GingerBlur now features more accounts that can be added including "LinkedIN," "Flickr," and more!
    Set up multiple home screen profiles!
    Hit the menu button from your home screen, and you'll notice a new "Profiles" option. You can set up 2 other profiles for a total of 3 different profiles, with seven screens each, that is 21 different screens you can have set up!
    macpro88's Avatar
    20491
    6,938
    320 times
    Better battery life and power management!
    Better battery life! Just what we have ALL been waiting for!
    The first thing you can do, is hold down the power button, you will now notice a new feature, the "Sleep" feature! Its a low power state of readiness similar to putting your computer to sleep. Instant on, just hold the power button down for a few seconds and your phone springs back to life!
    The new power management is very nice. Gives a more detailed view of whats going on and what is eating your battery. You will also notice the new graph at the top. Tap it! And an even more detailed graph pops up!
    You will also notice, under Wi-Fi settings, that you can now select when the Wi-Fi sleeps, which will greatly increase battery life. There is also a new "Data Saver" option that allows the use of only downloading large files, email attachments, Market apps and updates over Wi-Fi only, that way you can be more conscious about how much data you are using.
    Field test of the new "Sleep Mode!"
    Please notice that this says 14 DAYS and NOT 14 HOURS. I took a vacation for two weeks and placed my phone in the new sleep mode, set it down, and forgot about it for the two weeks. End result:
    macpro88's Avatar
    20491
    6,938
    320 times
    Bluetooth Bypass!
    Allow Voice Commands to be launched via Bluetooth Multi-function button while device is locked.
    Hard Menu Key-->Settings-->Location & security-->Allow Bluetooth bypass
    Data encryption!
    NOTE! If you are rooted, you can NOT encrypt the device, this will only work on stock OTA!
    We can now encrypt our Droid X's! Protect the data on your phone or memory card. This will require that you set up a screen lock.
    mission214 likes this.
    macpro88's Avatar
    20491
    6,938
    320 times
    Better app management!
    There is now a new interface for managing your apps. With nice informative graphs at the bottom keeping you informed of how much storage you are using as well as how much RAM is being used as well. You will notice the four tabs at the top. Tap each tab to view more information.
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    Nice job mac...thread is stickied for now.
    macpro88's Avatar
    20491
    6,938
    320 times
    Thank You, still a work in progress, waiting for my battery to die so I can post screens of how I am lasting more than 24hrs on stock GB
    Points: 4,538, Level: 42
    Level completed: 94%, Points required for next Level: 12
    Overall activity: 1.3%
    Tagger Second ClassCreated Album pictures100 Experience Points31 days registered7 days registered
    goblueboy's Avatar
    21324
    Ohio, USA
    383
    30 times
    great work bro
    Supported / Loving it. Started off a Gummy user (thanks to Wugfresh and Droid-Xer)
    Thanks to Gorgarath for helping me jump start into META-INF
    My posts: Hardstyle Biohazard Boot Logo , Video Live Wallpaper recommendation w/ Dragonball z clips , Halo Wars - "Forge is Down" Notification Tone, My First Icon Pack, Goblueboy's Blue Icons!
    macpro88's Avatar
    20491
    6,938
    320 times
    Quote Originally Posted by goblueboy View Post
    great work bro
    Thanks The new CRT Off animations is my favorite lol
    Points: 2,775, Level: 32
    Level completed: 17%, Points required for next Level: 125
    Basis's Avatar
    24714
    Tennessee via Detroit
    295
    41 times
    mine too, think I ran about half my battery down locking and unlocking my phone lol
  1. Replies: 8
    Last Post: 11-10-2011, 03:34 PM
  2. Replies: 37
    Last Post: 05-24-2011, 11:04 PM
  3. DROID X - Tips for extending battery life
    Last Post: 09-28-2010, 09:18 AM
  4. Tips on extending battery life?
    By Hephaestus in forum Droid X Help
    Last Post: 07-25-2010, 12:23 AM
  5. Tips for better battery life
    By PorcPuffer in forum Droid X General Discussion
    Last Post: 07-17-2010, 11:27 AM
battery saver for gingerbread
best battery saver for gingerbread
droid x battery life tips
droid x gingerbread battery life
droid x gingerbread tips
droid x gingerbread tips and tricks
droid x gingerbread tricks
droid x tips and tricks 2011
gingerbread battery saver
gingerbread battery tips
