This is a discussion on GB - Tips/Tricks/Better Battery Life/And Everything Else! within the Gingerbread General Discussion forums, part of the Droid X Gingerbread Forum category; Originally Posted by vudugan People, if you are using LPP and the GB app drawer here is the work around to add shortcuts to your ...
Its finished and updated! Got most of what I though was important, hope you guys enjoy!
Resurrection:
Since a month or two is ancient history in the evolution of Droid development, and I thought of starting a thread but this title seems most appropriate, I'm wondering about Tips and Tricks for making Rooted Stock Blur Gingerbread .602 / .605 run awesome..
I'm thinking things like display fixes, config tweaks/hacks, etc. If this thread isn't appropriate, just slap me because I'm just too whacked on some serious french roast this morning.
I need two DX's.. One to try rom's on and one for MIUI because it's THE daily driver for me so I'm not messin' with it.
Haha, whacked on French Toast, that made me laugh.... lol
Anyways, a general guide to making GB on the DX smoother would be a good idea me thinks, but my issue is that it might not apply to everyone as each user is a different type of user. A bland, general, bare minimum guide might just be too general to really be of any help, though it could serve as a good starting point, but it would probably mostly require users to be rooted and not all users are rooted, but who knows, I shall look into this, see what I can muster up.
"French Toast".. Freudian slip? Somebody's ready for lunch! LOL!!!
Yeah I was after definitely Stock and Rooted as the two main criteria, so yeah for unrooted folks not much you can do anyway besides apps and general settings stuff I suppose. I'll start a thread, try to at least contribute what I've found, and hopefully some pro's will chime in.
Not surprising with most rooted folks running mostly blurless roms instead of blur as I've done since March, there's not much I've found on simply making the "stock" rom run killer. Stuff like "what's safe in 602/605 to freeze in Tibu", etc. Any and every facet of stock blur rooted performance.
Stock but rooted GB .602 and .605 Performance Tips and Tricks
Thread started. Definitely, when I can I'll list the ones I've frozen but I'd love it if a growing list of "safe to freeze" apps in the Op post. A 1-stop list for GB blur users. Granted the goal was also for any other performance hacks such as that killer display setting thread for MIUI CM7. I've asked in that thread about applying the tool to stock blur. I imagine also a bunch of stuff may be rehash from what's been applied to froyo as well, so I'll comb through a bunch of older threads as I can. I'd say anything that makes blur including stock blur launcher just plain run better, and better battery life.
Got two days out of it
Miui ROM
Brightness controls
Undervolt
Turning off the data when not in use
Nothing more
Beamed from my DroidX
