Wifi will not work on any .621 rom I try
This is a discussion on Wifi will not work on any .621 rom I try within the Gingerbread Development and Hacking forums, part of the Droid X Gingerbread Forum category; I have flashed apex, vortex and liberty from here http://www.droidxforums.com/forum/gi...621-604-a.html Wifi would not connect on any of them. I SBF'd and did a clean new ...
Thread: Wifi will not work on any .621 rom I try
    Points: 89, Level: 1
    Level completed: 78%, Points required for next Level: 11
    Overall activity: 2.5%
    yamahammer342's Avatar
    65428
    May 2013
    7
    I have flashed apex, vortex and liberty from here [ROMs] Multi-ROM Thread - Blur-Based ROMs for those on .621/.604! Wifi would not connect on any of them. I SBF'd and did a clean new install with liberty and again no Wifi. It worked fine after SBF and after i rooted. But as soon as I installed a rom Wifi does a obtaining IP address/seaching loop. Any ideas?
    65428
    May 2013
    7
    Ok, I overlooked the WIFI fix listed on the thread with the .621 roms. I installed the fix and now its working. Sorry for this post It can be deleted if need be.
    Points: 45,910, Level: 100
    DirtyDroid's Avatar
    28665
    Upstate,NY
    14,576
    384 times
    Glad yah got it working :thumbup: closing at your request
    Sent from my SCH-I535 using Tapatalk 2
  1. Wifi tether won't work with miui.us rom 1.10.7
    By vwbajakid in forum Droid X General Discussion
    Last Post: 11-16-2011, 08:41 AM
  2. WiFi will not work if using AES
    By DJX in forum Droid X Help
    Last Post: 06-09-2011, 04:19 PM
  3. Any solid work around for the wifi tethering on gingerbread?
    By Gotsaved289 in forum Gingerbread General Discussion
    Last Post: 06-04-2011, 01:47 PM
  4. Wireless Tether doesn't work with Wifi TV
    By renthorin in forum Droid X Hacks
    Last Post: 12-27-2010, 08:59 PM
  5. Data wont work with wifi on
    By Fins in forum Droid X Help
    Last Post: 09-07-2010, 09:16 PM
droid x .621 roms
droid x 621 roms
droid x 621. wifi not working
droud x .621 wifi fix?
liberty 3 droid x 621
liberty rom droid x 621 wifi
liberty rom wifi
liberty wifi loop fix
roms that work on droidx 621
wifi wont turn on rom
