Droid X Goes To Stock Recovery After CWM Flash...Won't Install ROM
This is a discussion on Droid X Goes To Stock Recovery After CWM Flash...Won't Install ROM within the Gingerbread Development and Hacking forums, part of the Droid X Gingerbread Forum category; First off, I'm new here. I'm using a Droid X .605 on Gingerbread 2.3.3 (updated OTA). It's obviously been rooted, with OneClickRoot. I'm trying to ...
Like Tree2Likes
  • 1 Post By Nemo aeternamn
Thread: Droid X Goes To Stock Recovery After CWM Flash...Won't Install ROM
    Points: 378, Level: 7
    Level completed: 56%, Points required for next Level: 22
    250 Experience Points31 days registered7 days registered100 Experience Points
    PeacemakerDawg's Avatar
    54975
    Jan 2012
    46
    Question Droid X Goes To Stock Recovery After CWM Flash...Won't Install ROM
    I'm trying to install the MIUI ROM on my Droid X, and I've followed all the steps. First, I downloaded ROM manager, then flashed ClockWorkMod 5.0.2.0. I have a .zip of the rom on my SD card, and I've made sure the SD card has been mounted. I select a ROM to install, and select all options that come afterward. Then it prompts me to reboot into CWM to start the installation.
    The problem that follows is that instead of booting into CWM, it keeps booting into stock recovery. For three hours, I've been searching for an answer, but I can't find ANY. I know that there is one solution (deleting data from /preinstall), but I can't find any data there using Root Explorer Lite.
    Every tool I'm using has Superuser permission. What am I doing wrong? Can someone please help me? You'll have to explain it in step format, because I only have a decent knowledge on how Android runs and works. Hope to get a lot of replies, and not end up with 100 views yet no replies.
    If any additional info is needed, I will provide it.
    Thanks guys.
    Points: 26,638, Level: 97
    Level completed: 29%, Points required for next Level: 712
    Overall activity: 62.2%
    Nemo aeternamn's Avatar
    37333
    Mo-ab
    7,738
    165 times
    Do you have Droid 2 bootstrap?
    Rom manager doesn't hijack the recovery
    PeacemakerDawg likes this.
    Post Script:
    Nemo Aeternamn Wallpapers
    54975
    Jan 2012
    46
    Just downloaded it now. All I need to do is tap "Bootstrap Recovery" right? I seriously don't want to damage any internal files. And is it confirmed working on Gingerbread? All threads about it seem to be two years old.
    Hallo.
    37333
    Mo-ab
    7,738
    165 times
    Bootstrap recovery... Then reboot recovery...
    The Droid 2 is updated to work better on ginger bread...
    It'll work just fine...
    Post Script:
  1. Flash custom rom from stock recovery?
    By fersayken2 in forum Droid X General Discussion
    Last Post: 03-14-2011, 08:59 PM
  2. Replies: 5
    Last Post: 02-05-2011, 11:14 PM
  3. Replies: 8
    Last Post: 01-13-2011, 10:16 PM
  4. Droid X Boot Looping After RSDLite Flash -- No Recovery
    By robbiem in forum Droid X Rescue Squad
    Last Post: 12-27-2010, 03:35 AM
  5. 2.2 did not install flash
    By newinfl80 in forum Droid X Help
    Last Post: 09-25-2010, 04:28 PM
boot cwm droid x
boot into cwm recovery droid x
cwm droid x
droid x cwm
droid x cwm install
droid x cwm recovery
droid x stock recovery
flash cwm droid x
install cwm on droid x
