How to Calibrate Battery And Charge Battery To Max mV
This is a discussion on How to Calibrate Battery And Charge Battery To Max mV within the Gingerbread Development and Hacking forums, part of the Droid X Gingerbread Forum category; Battery Calibration and Max mV You must be rooted to utilize this method 1. While in Android, charge up to 100% and leave the phone ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: How to Calibrate Battery And Charge Battery To Max mV
    Banned
    Points: 6,358, Level: 52
    Level completed: 4%, Points required for next Level: 192
    Overall activity: 59.1%
    500 Experience Points250 Experience PointsThree Friends100 Experience Points7 days registered
    cobracon71's Avatar
    24256
    chester,va
    1,445
    113 times
    1. While in Android, charge up to 100% and leave the phone plugged in.
    2. Using root explorer or es file explorer delete /data/system/batterystats.bin
    3. Remove back cover
    4. Press Power and choose to reboot normally.
    5. When the screen goes black and the lights go out, pull out the battery before you get the M logo. It will probably still work after the M logo shows up but that's how I do it.
    6. Surprise: The phone will boot up without the battery! - Mine does - every time
    Note: Batterystats.bin is recreated when you see the M logo - even though the battery isn't in the phone.
    Go to Step 8 if the phone booted up as described.
    7. If it doesn't boot up and you see the battery with the ?
    ..........a) Put the battery back in (you will see 60%),
    ..........b) Power off the phone (press power until LED light goes out)
    ..........c) Power on the phone (press power until you see the M logo)
    ..........d) Remove battery... and watch bootanimation...
    8. a) After the surprise of seeing the boot animation without a battery, you will then see the lock screen along with a "No SIM card error" and no signal.
    ...... Put the battery back in - the SIM card error will disappear, you will get a signal, it will show 60% full and the icon will show the battery charging.
    ...... Go to Step 9 if this works as planned. If it doesn't, reboot (again without the battery) and use step 8b instead of step 8a.
    ... b) Put the battery back in during the bootanimation, but after the haptic feedback/vibration (and the buttons along the bottom light up).
    ....... On a normal reboot, you can actually slide and unlock the phone when you get the vibration during the boot animation. You knew that, right?
    9. Use your phone normally while you calibrate the battery
    10. Let it fill it up to 100% + 15 minutes or so. When it is truly finished charging, the battery should be cool.
    11. If the phone is running hot, weird things can happen. For example, you may get no signal when you put the battery back in or the battery doesn't begin charging (the status bar battery icon doesn't change). Just let the phone cool off and it should work next time.
    100% full is approximately 4200mV
    As you can see in the cap below, it's showing only 60% at 4241mV (This was after booting up without the battery and putting the battery in)
    A few minutes later, still plugged in, it showed 100% at 4225mV and then it went up to 4230mV.
    Finally, I then unplugged the phone and I got a reading of 4196mV
    This is proven to work and works well... I did not come up with this nor do I take credit for it... I copied and pasted this on word from another forum but could not tell you where lol
    I am not responsible for what you may or may not do to your phone by doing this
    Moderators if this has been previously posted please discard the thread thank you
    Droid X Forums Rule
    mikey2487 likes this.
    Points: 15,172, Level: 79
    Overall activity: 14.0%
    cory46's Avatar
    8051
    4,768
    125 times
    Here maybe
    http://www.DroidXForums.com/forum/sh...p=428673<br />
    Battery calibration (New method?)
    Banned
    cobracon71's Avatar
    24256
    chester,va
    1,445
    113 times
    maanneee this is the second thread ive started that you have hijacked with another link what up with that llmaaoo u did it to my uot kitchen thread also
    cory46's Avatar
    8051
    4,768
    125 times
    Quote Originally Posted by cobracon71 View Post
    Ha I did? I'll have to investigate this one haha. Sorry in advance if I did
    Most Creative Screenshot
    Points: 8,944, Level: 63
    Level completed: 65%, Points required for next Level: 106
    silver04v's Avatar
    26597
    New Hampshire
    1,492
    36 times
    So, is this tested on the dx?
    Are the directions the same. What's with the Sim card error stuff.
    taking miui for a spin
    Droid X powered by ICS
    I've got my SBF badge.
    Points: 4,159, Level: 41
    Level completed: 5%, Points required for next Level: 191
    Scram's Avatar
    36066
    Jersey Shore
    492
    10 times
    Quote Originally Posted by silver04v View Post
    Yes. Works on the X...
    Sent from my liberated DX
    Points: 2,287, Level: 28
    Level completed: 92%, Points required for next Level: 13
    mikey2487's Avatar
    35020
    263
    i ended up just doing this on my phone and everything worked fine. only thing i noticed is that when i let it charge from 60 to 100 it didn't go 60,70,80, etc to 100 it just went 60% to 100% but when i did the battery calibration i was at 4176 so i'm assuming it worked fine. thanks for this cobra!!
    Points: 9,280, Level: 64
    ryant35's Avatar
    7730
    SoCal
    1,706
    57 times
    Quote Originally Posted by mikey2487 View Post
    Mine did exactly the same thing.
    Liberty 3 -- too many roms too little time.
    Points: 1,167, Level: 18
    Level completed: 67%, Points required for next Level: 33
    lindross's Avatar
    32764
    Indiana
    14
    Quote Originally Posted by ryant35 View Post
    Same here so I can only assume it went right.
    Droid X
    VorteX RC1 rom, rooted, overclocked @ 1.2Ghz, Go Launcher themed
    Banned
    cobracon71's Avatar
    24256
    chester,va
    1,445
    113 times
    that is correct it will jump from 60 to 100 but make sure you leave in on charge a additional 20 to 30 minutes for max charge
  1. how to calibrate extended battery?
    By Yamahajs93 in forum Droid X Help
    Last Post: 07-27-2011, 11:54 PM
  2. Correct way to re-calibrate battery stats?
    By Austin1227 DX in forum Droid X Help
    Last Post: 07-18-2011, 10:37 PM
  3. Battery charge problem
    By Willup in forum Droid X Help
    Last Post: 04-29-2011, 01:54 PM
  4. First Charge of a new battery?
    By cantstopthesignal in forum Droid X General Discussion
    Last Post: 02-23-2011, 05:50 AM
  5. No USB charge, hot battery?
    By mreyeball in forum Droid X General Discussion
    Last Post: 09-08-2010, 01:54 PM
4200 mv
Battery mV
android battery mv
battery calibration 3mv
battery calibration mv
calibrate droid x battery
droid bionic battery calibration
droid x battery calibration
mv battery
recalibrate battery droid x
