My Droid X is hot and burns through the battery
This is a discussion on My Droid X is hot and burns through the battery within the Gingerbread Development and Hacking forums, part of the Droid X Gingerbread Forum category; Up until a couple months ago I was running stock Moto Blur Froyo rooted with no problems at all. But after upgrading to Gingerbread Blur ...
Results 1 to 8 of 8
Thread: My Droid X is hot and burns through the battery
    Points: 100, Level: 1
    31 days registered7 days registeredTagger Second Class
    rockinyp's Avatar
    48592
    Sep 2011
    MN
    Unhappy My Droid X is hot and burns through the battery
    Up until a couple months ago I was running stock Moto Blur Froyo rooted with no problems at all. But after upgrading to Gingerbread Blur rooted, a few weeks later the back of the bottom quarter of the phone started warm and it would drain the battery by about 15% per hour (5 hours of sitting in idle standby to go from a full charge to dead). I checked the CPU usage and it was normal (floating from 5% to 20% when idle), killed all apps, restarted the phone, let it sit without the battery for a while, uninstalled recently installed apps, turned off GPS and wifi, and nothing seemed to fix it. But then it just stopped on its own and the phone went back to normal.
    Well, that's happened several times. The last time it happened, I "fixed" it by updating Gingerbread to the latest rooted version, which basically entailed of a complete phone wipe/format and reinstalled the newest rooted Gingerbread as a clean install. However, the problem just came back this past week again. I'm not sure what to do about it. Although I couldn't find anyone else having this issue, I'm guessing it has something to do with Gingerbread, not my hardware since I never had this issue on Froyo. I thought maybe switching to a custom ROM would solve the problem, but before I do that I thought I'd ask here to see if anyone has an idea of what's going on with my phone and how to fix this problem and if moving to a custom ROM would even fix it in the first place. Any help or direction you guys could provide would be greatly appreciated. Thanks!
    Points: 17,929, Level: 85
    Snow02's Avatar
    22940
    3,769
    142 times
    You probably have a process running wild. If you don't feel like tracking it down, a simple factory reset should resolve it.
    rockinyp's Avatar
    48592
    Sep 2011
    MN
    Quote Originally Posted by Snow02 View Post
    How would I go about tracking it down?
    That's what I thought, too, but I thought the clean install of the Gingerbread update would fix that, but it didn't. Maybe because I restored my apps/settings with Titanium Backup? Would that just bring the problem process back?
    Points: 29,424, Level: 99
    Nemo aeternamn's Avatar
    37333
    Mo-ab
    7,738
    165 times
    if you look in your battery life.. it will show you what's using the battery...
    and there are also apps for gingerbread that will give you a better brake down of what's drawing the power
    Post Script:
    Nemo Aeternamn Wallpapers
    Points: 717, Level: 14
    Overall activity: 1.4%
    OldEmt's Avatar
    39821
    Southern Colorado
    144
    Had the same problem. I blamed it on something amiss in an app that I was reloading with TiBu, did my restore from market and everything was fine.
    What am I running right now? Heck, I'm not sure I know!
    Wugfresh SBFboot - the easy way to sbf
    rockinyp's Avatar
    48592
    Sep 2011
    MN
    Quote Originally Posted by Nemo aeternamn View Post
    It says:
    Display - 42%
    Phone idle - 11%
    Cell standby - 10%
    Motorola Services - 6%
    and then some other apps I use all with a low percentage.
    Is there an app you recommend that breaks down the usage better? I use System Panel Lite to monitor CPU and Memory and to end processes, but that doesn't seem to say anything about the battery.
    37333
    Mo-ab
    7,738
    165 times
    bettrrbatterystats is a great app for a better brake down of the battery usage
    Post Script:
    Snow02's Avatar
    22940
    3,769
    142 times
    More than likely something would show up in the battery stats. Android system is the usual one when you have a runaway process. You're right, that doesn't appear to be the problem.
    Check the detailed stats by pressing the graph at the top and make sure the phone isn't wake-locked. By that I mean make sure the awake bar isn't highlighted all the way across the screen. If something is keeping the phone from sleeping that would also kill your battery rather quickly.
    Also, not restoring from titanium after another factory reset would be a good idea to see if it is in fact an app causing whatever the problem is.
  1. Replies: 31
    Last Post: 08-08-2011, 03:42 PM
  2. droid os using 90% battery?
    By sixfootfive in forum Droid X Stock Issues
    Last Post: 06-25-2011, 11:04 AM
  3. New Droid X battery Available
    By CellBattExpert in forum Droid X Accessories
    Last Post: 09-09-2010, 09:31 AM
  4. My Droid X definitely has a battery or battery hog problem... Screenshots Inside
    By Talldarknfugly in forum Droid X General Discussion
    Last Post: 08-03-2010, 11:44 AM
  5. Replies: 10
    Last Post: 07-11-2010, 05:16 PM
My DROID x is hot
droid x battery dies fast
droid x battery hot
droid x gets hot and battery dies
droid x hot
droid x hot battery
droid x runs hot
my droid x running hot
why is my droid hot
why is my droid x hot
