Help
This is a discussion on Help within the Gingerbread Development and Hacking forums, part of the Droid X Gingerbread Forum category; I am trying to root but it didn't work I downloaded all the stuff and loaded it. But now im stuck with a roped 2.2.1 ...
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
Like Tree30Likes
Thread: Help
    Points: 372, Level: 7
    Level completed: 44%, Points required for next Level: 28
    Overall activity: 0.0%
    ovrdon02340's Avatar
    48478
    Sep 2011
    23
    Angry Help
    I am trying to root but it didn't work I downloaded all the stuff and loaded it. But now im stuck with a roped 2.2.1 android version and when I go to install dxgbrooted.zip all it dose is abort the install. Please help.
    Banned
    Points: 6,358, Level: 52
    Level completed: 4%, Points required for next Level: 192
    Overall activity: 59.1%
    500 Experience Points250 Experience PointsThree Friends100 Experience Points7 days registered
    cobracon71's Avatar
    24256
    chester,va
    1,445
    113 times
    ok what system are you onn froyo?
    ehnobigdeal likes this.
    48478
    Sep 2011
    23
    Not sure how do you know I'm new.
    Banned
    cobracon71's Avatar
    24256
    chester,va
    1,445
    113 times
    Quote Originally Posted by ovrdon02340 View Post
    go to settings
    scroll all th e way down to about fone
    tell me what it says
    are you rooted ?
    48478
    Sep 2011
    23
    The android version is 2.2.1 and that is all it says the other version number is 2.3.340 with more random number. And yes rooted with z4.
    Banned
    cobracon71's Avatar
    24256
    chester,va
    1,445
    113 times
    ok your on froyo
    i assume you have bootstrap installed
    also do you have any rom installed?
    48478
    Sep 2011
    23
    Is bootstrap needed and y if you know and all I have is dxgbrooted.zip
    Banned
    cobracon71's Avatar
    24256
    chester,va
    1,445
    113 times
    The android version is 2.2.1 and that is all it says the other version number is 2.3.340 with more random number. And yes rooted with z4.<br>
    <br>
    ok your on froyo <br>i assume you have bootstrap installed <br>also do you have any rom installed? yes you need droid x bootstrap in order to flash any files
    how are you currently trying to install this
    Banned
    cobracon71's Avatar
    24256
    chester,va
    1,445
    113 times
    rom manager ?
    48478
    Sep 2011
    23
    Through the boot menu the one you hold home and power is that on the MP.
