phone stuck at bootloader screen. help.
This is a discussion on phone stuck at bootloader screen. help. within the Gingerbread Development and Hacking forums, part of the Droid X Gingerbread Forum category; so i tried installing .602 with sbfboot. i charged my phone to 90% to sbf. ran sbf program. restarted with phone plugged in. it did ...
Results 1 to 9 of 9
Thread: phone stuck at bootloader screen. help.
    Points: 1,130, Level: 18
    Level completed: 30%, Points required for next Level: 70
    kn0wsk1ll's Avatar
    45129
    Aug 2011
    75
    so i tried installing .602 with sbfboot. i charged my phone to 90% to sbf. ran sbf program. restarted with phone plugged in. it did its thing. when it was done it said to take the battery outta my phone and reinstall. then to hold power and home key when restarting. i did, but it doesnt show lil droid guy with triangle. it goes to bootloader screen. the screen displays this:
    Bootloader
    30.04
    Err: A5,69,35,00,21
    Battery OK
    OK to Program
    Connect USB
    Data Cable
    what did i do wrong?
    RS Team Leader
    Points: 26,658, Level: 97
    Level completed: 31%, Points required for next Level: 692
    Overall activity: 99.9%
    Activity Award
    popcenator's Avatar
    21238
    Omaha, NE
    8,258
    179 times
    If by restarted the phone you mean you rebooted into the bootloader, then ran SBFBoot, it sounds like you had the process right. Have you tried any other method?
    kn0wsk1ll's Avatar
    45129
    Aug 2011
    75
    no, i just retried it and it didnt work. also where was the .602 file supposed to go? it never asked me for it. it just started flashing.
    RS Team Leader
    Activity Award
    popcenator's Avatar
    21238
    Omaha, NE
    8,258
    179 times
    It's built into the program. Try this method, it's pretty easy and there's proven success with it.
    Points: 994, Level: 16
    Level completed: 94%, Points required for next Level: 6
    thearchiexdm32's Avatar
    37239
    36
    Its way better if you just sbf back to group and update from there. Its a little bit more time consuming but better. Make sure the stuff you download is compatible with your pc cuz depending on if you have windows 7 or xp you have to download rsd 4.8 or 4.9. Well hope this was helpful. I've been in your situation before so just keep researching and hope you get it.
    Points: 26,638, Level: 97
    Level completed: 29%, Points required for next Level: 712
    Overall activity: 62.2%
    Nemo aeternamn's Avatar
    37333
    Mo-ab
    7,738
    165 times
    +1 to 1kds's method... it's alot less hassle free...
    Edit: err.. the one that popcentor linked
    Post Script:
    Nemo Aeternamn Wallpapers
    Points: 681, Level: 13
    Level completed: 62%, Points required for next Level: 19
    droidxter's Avatar
    25708
    St.Louis, MO
    5
    ok heres one....... i was attempting to get to prerooted GB, using the instructions for the two part (flash?) i found on droid life.com. sbf bak to froyo, worked fine, rerooted with z4, installed d2bootastrap, in bsrecovery i flashed the first part, seemed ok said all good, left me in bootstrap, when i flashed the 2nd part it said there was no file....... now im stuck. tried it a few more times got the same msg. tried to go back to froyo from recovery cant. enerd up pulling bat to restart, now i got a boot loop on the grey moto screen. got to stock recovey tried to factory reset, no good. stuck at work for 12 hrs with no way to sbf back..... any other options? will sbf work? what should i sbf back to froyo? or is there a better option>?
    37333
    Mo-ab
    7,738
    165 times
    ya... you will have to sbf... there isn't another option where you'r at... but and sbf will work just fine
    sbf to 602... then use the one click method... it's easier then this...
    and it's less hassle..
    1kds sbf method works good... i prefer it to rsd
    Post Script:
    droidxter's Avatar
    25708
    St.Louis, MO
    5
    I figured that. Thanks for the tip. 12hr shift with no X is BOOOOORRRRIIIINNNNNGGGGGG!!!!!!!! Getting paid overtime to cruse the fourm makes it all good!!!
  1. Need help please! Stuck at Bootloader screen
    By bjesse60 in forum Droid X Rescue Squad
    Last Post: 08-22-2011, 08:26 PM
  2. Help!! Stuck on Bootloader screen!!!
    By dmwalrad in forum Droid X Help
    Last Post: 06-01-2011, 05:05 AM
  3. Replies: 1
    Last Post: 05-26-2011, 06:48 AM
  4. Phone is stuck in Bootloader
    By Achiga in forum Droid X Rescue Squad
    Last Post: 04-23-2011, 11:12 PM
  5. Stuck at Bootloader screen
    By Carpetman in forum Droid X Help
    Last Post: 04-21-2011, 08:06 AM
android bootloader screen
android phone bootloader screen
android phone stuck on boot screen
bootloader screen on droid x
droid pro stuck in bootloader
droid pro stuck on bootloader
droid x bootloader screen
droid x bootloader screen stuck
droid x stuck in bootloader
phone stuck in bootloader
