Easier way than Ninjamorphing?
This is a discussion on Easier way than Ninjamorphing? within the Gingerbread Development and Hacking forums, part of the Droid X Gingerbread Forum category; I just went to the Shuiji mod and am happy w/ everything. I'd like to change my status bar icons. I remember a few months ...
Results 1 to 7 of 7
Thread: Easier way than Ninjamorphing?
    Points: 3,384, Level: 36
    Level completed: 23%, Points required for next Level: 116
    psykotikz's Avatar
    15211
    Long Island, NY
    302
    33 times
    I just went to the Shuiji mod and am happy w/ everything. I'd like to change my status bar icons. I remember a few months ago when I wanted to do that (before cm7 and miui came out) the only way to do it was to ninja morph and that was a major pain in the a$$. Has an easier way been discovered?
    Points: 15,172, Level: 79
    Overall activity: 14.0%
    cory46's Avatar
    8051
    4,768
    125 times
    Yeah using apkmanager or apktool on your computer haha or just flashing a theme haha no help I know but really it is easy png's l once you get the hang of it
    1Kitkatdidiwags
    Points: 11,004, Level: 69
    Level completed: 39%, Points required for next Level: 246
    Overall activity: 4.7%
    shawn's Avatar
    27626
    eugene, oregon
    1,118
    54 times
    I just take the rom zip place on PC then use 7zip to open archive swap whatever I want then place on phone and flash
    DX2 eclipse with some tweaks
    psykotikz's Avatar
    15211
    Long Island, NY
    302
    33 times
    Quote Originally Posted by shawn View Post
    that's a cool idea shawn. heres one problem i see. I been finding all the icons I want from xda and all the people are putting the status bar icons in .mtz's, i guess for miui.
    so do i either need to find the stock images of these and do what you said or is there something i can do with .mtz not using miui?
    cory46's Avatar
    8051
    4,768
    125 times
    Just pull the images from the mtz or rename it to zip you can't flash the mtz because it lacks the folder structure and scripts for anything non miui
    1Kitkatdidiwags
    Points: 1,967, Level: 26
    Level completed: 67%, Points required for next Level: 33
    Detonation's Avatar
    21512
    Wisconsin
    138
    If all you want to do is edit png's, you can take the .apk, extract it like a .zip, swap the png's, and zip it back up. This is essential what ninjamorph does for you (it extracts it to sdcard/AndroidThemes).
    However, there are some visuals that are configured in the binary xml. For that you need something to decompile/recompile the apk. ApkManager works well for, but has a bit of a learning curve.
    And as cory mentioned above, mtz files are just like zips, so just extract those and find the png's you want.
    shawn's Avatar
    27626
    eugene, oregon
    1,118
    54 times
  1. Ninjamorphing XML files?
    By jline123 in forum Droid X Hacks
    Last Post: 08-09-2011, 12:42 AM
  2. Folders to locate apps easier
    By cdt12271 in forum Droid X Help
    Last Post: 05-18-2011, 03:44 PM
  3. Searching through Contacts Easier??
    By jamesyun in forum Droid X Apps
    Last Post: 09-29-2010, 07:54 PM
  4. Droid X Root Easier Way. Need Help with ADB though.
    By w00tn3ss in forum Droid X Hacks
    Last Post: 09-28-2010, 10:58 AM
  5. Is there an easier way to toggle GPS?
    By Asharad in forum Droid X General Discussion
    Last Post: 07-29-2010, 09:13 AM
NinjaMorph
miui ninjamorph
ninja morph not working
ninja morph xda
ninjamorph for windows
ninjamorph gingerbread
ninjamorph not working
ninjamorph xda
xda ninja morph
xda ninjamorph
