[HOW TO] BE READY to FLASH GB/2nd-INIT ROMs
This is a discussion on [HOW TO] BE READY to FLASH GB/2nd-INIT ROMs within the Gingerbread Development and Hacking forums, part of the Droid X Gingerbread Forum category; Little help guide on how to be prepared to flash Gingerbread ROM's and 2nd-INIT based ROM's! Part 1: 2nd-INIT, what is is, and what it ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Like Tree4Likes
Thread: [HOW TO] BE READY to FLASH GB/2nd-INIT ROMs
    Points: 49,198, Level: 100
    Overall activity: 3.0%
    macpro88's Avatar
    20491
    6,938
    320 times
    Lightbulb [HOW TO] BE READY to FLASH GB/2nd-INIT ROMs
    Part 1: 2nd-INIT, what is is, and what it is not.
    The first and fore most thing you need to do first is READ! I can not stress this enough on how important it is to read up and understand what you are doing to your phone! Detailed instructions are always found in the original and first post of the ROM you are trying to flash!
    So now, what is 2nd-INIT? Read this here: Still Loading ... blog:2011-06-14:2nd-init._what_it_is_and_how_it_works
    tl;dr (too long; didn't read) version: 2nd-init uses PFM to reload the initialization process, 2nd-init does NOT unlock the bootloader or let you run a custom kernel.
    But still read that blog! Its a good read for us techie people .
    2nd-INIT base ROM's are ROM's based off of CyanogenMOD's open source platform which has been built from source based on AOSP, Android Open Source Project, which is all built from the latest and greatest Android OS, Android 2.3 Gingerbread. It is truly pure Android, with everything built from the ground up. These 2nd-INIT ROM's are built for Motorola devices only! Due to the fact we have a locked bootloader, other wise, CM (CyanogenMOD) base ROM's work on open devices with no issues and without the need for the 2nd-INIT process.
    So far, we have the following 2nd-INIT ROM's for the DROID X:
    -CyanogenMOD 7
    -SSX (Simply Stunning)
    -MIUI
    -Liquid
    -Justice (Team Liberty)
    Another thing everyone needs to know about 2nd-INIT, is that it only works on the older kernel from the Froyo 2.3.340 builds. This means that it will not work coming from any of the Gingerbread versions we currently have for the DROID X due to the fact they have an update Gingerbread kernel.
    (This does not mean that you are not running Gingerbread (Android 2.3), however. The base operating system for all 2nd-INIT ROM's is is fact Gingerbread 2.3.3 or higher, some are running 2.3.4 and soon to be 2.3.5.)
    The kernel version should be: 2.6.32.9
    With this in mind, to flash a 2nd-INIT ROM, you must be on this kernel! Meaning you must already be on another 2nd-INIT ROM, you must be on Froyo, or you must be on a Froyo ROM.
    Flashing from Gingerbread builds with the new Gingerbread kernel will result in a brick.
    Part 2: Preparation
    The first step of easy flashing, is to always have key essential application files located on your SD card for easy access.
    So create a new folder in the ROOT of your SD card, name it Application or something to that effect.
    Place these files in there:
    -z4root [FIND HERE]
    -Droid X/2 Bootstrap app(s). Really don't need both, but I do just in case. Find in the Market
    -Root system file explorer, like "Root Explorer."
    To move these files from the internal phone storage to your SD card, open up your root file explorer app, navigate to /data/app/ and scroll down to find the app you want to move, long press and select COPY, then navigate back to your SD card and paste it there.
    Having these essential apps ready to install from your SD card makes it a lot easier to flash after you have done an SBF. This way you can skip the activation (by tapping the four corners of the set up screen when the droid comes up and says "Touch Me!") and go straight to rooting, bootstraping, and flashing a ROM without having to set anything up, since you are just going to wipe all that out anyways during the ROM installation.
    The second step is to get back to Froyo base, if you have not already done so. You can get back by going through the SBF process using the Froyo 2.3.340 full system file.
    Detail instructions here:
    SBF - Detailed Guide for Success - Windows 7
    If you have issues SBF'ing, please post in the appropriate method thread above! Do not post SBF issues here please.
    Part 3: On a 2nd-INIT ROM
    VERY IMPORTANT! Once you are on a 2nd-INIT ROM, DO NOT UNDER ANY CIRCUMSTANCE FLASH THE DROID X OR DROID 2 BOOTSTRAP APPS! Custom recovery is already installed into these ROM's, flashing any one of the DX/2 Bootstraps will brick your phone!
    To access recovery from a 2nd-INIT ROM, either use the built in Reboot option from the power button menu, or use ROM Manager to access recovery.
    Also, in ROM Manager, you will notice that your Recovery version is 4.0.0.5 or higher, if it is not this, flash the new recovery but tapping on flash recovery and choosing the DROID X 2nd-INIT version.
    Also, each 2nd-INIT ROM has different options to offer. If you like flashing ROM's, try them all! Each one has been tailored differently and you may find you like one better than another.
    No two 2nd-INIT ROM's are equal, and this also means that not one is better than the other! It is all a mater of personal opinion based on what you like from the ROM.
    I hope this helps everyone out!
    sgthwjack, popcenator and OldEmt like this.
    Points: 717, Level: 14
    Overall activity: 1.4%
    OldEmt's Avatar
    39821
    Southern Colorado
    144
    Well, I don't know how you can explain it any better than that. Thanks again
    What am I running right now? Heck, I'm not sure I know!
    Wugfresh SBFboot - the easy way to sbf
    Points: 29,424, Level: 99
    Nemo aeternamn's Avatar
    37333
    Mo-ab
    7,738
    165 times
    Very well put... all the things i could try to explain about these new rom types(put a lot better then i could{and better derail})
    good to see a nice explanation of all i have learned with a side of refreshment
    Post Script:
    Nemo Aeternamn Wallpapers
    Points: 45,910, Level: 100
    DirtyDroid's Avatar
    28665
    Upstate,NY
    14,576
    384 times
    Nice write up Mac.!
    Points: 1,082, Level: 17
    Level completed: 82%, Points required for next Level: 18
    Chipworkz's Avatar
    37890
    80
    Just to be clear, when you are using the phrase "Brick" are you saying it will actually brick the phone beyond repair? Or are you meaning that you will need to SBF to fix it.
    Thanks for the detailed write up.
    Points: 5,976, Level: 50
    Level completed: 13%, Points required for next Level: 174
    tycoon177's Avatar
    20902
    Iowa
    787
    12 times
    Quote Originally Posted by Chipworkz View Post
    You would need to sbf
    macpro88's Avatar
    20491
    6,938
    320 times
    SBF to fix it, perma brick is beyond repair, that's usually when you do some kinda hardware damage. I don't know of anyone perma bricking a Droid X.
    Chipworkz's Avatar
    37890
    80
    Thanks, that is what I thought but just wanted to make sure. People see the word Brick and get afraid. From everything I have read, I didn't think it would be a perma brick as you called it but since this is taking it to another level with the 2nd init process, I just want to get clarification.
    Thanks again for all the details.
    Points: 6,060, Level: 50
    Level completed: 55%, Points required for next Level: 90
    Overall activity: 0.8%
    LiveToPonder's Avatar
    38822
    Long Island, NY....uhhh nope, I live in Seattle now :)
    1,414
    This is awesome Macpro! Really fantastic man...
    GS 3izzle but still rollin with the best forum ever...
    Shouts out to Wulf, XJacobX, BKDodger, Peakyboo, Mapatton82, Jersey, Rickw and Popcenator on the assist. It's good to be back!
    http://www.droidxforums.com/forum/gi...bluebread.html
    When VZW doesn't, DX Forums does...
    macpro88's Avatar
    20491
    6,938
    320 times
    As long as nothing interferes with changing the bootloader than you are good, and even if you some how change the bootloader than you just need the appropriate .sbf file. Doing so is actually very difficult lol. The 2nd-INIT process comes no where near putting your phone in harms way, this all happens after the bootloader has loaded the needed files to boot.
  1. 2nd init roms: animation issues
    By kochoid in forum Gingerbread Roms
    Last Post: 07-28-2011, 01:25 AM
  2. Ready to flash!
    By jtp755 in forum Gingerbread Roms
    Last Post: 06-28-2011, 07:09 AM
  3. Getting ready to flash, but just a simple question.
    By mrgforce in forum Droid X ROMs
    Last Post: 02-02-2011, 05:23 PM
  4. Rooted and ready to flash a rom
    By HarleyDad in forum Droid X General Discussion
    Last Post: 11-24-2010, 01:54 PM
  5. Ready to flash!
    By in forum Droid X ROMs
    Last Post: 12-31-1969, 07:00 PM
2nd init rom
2nd init roms
2nd init roms droid x
droid x 2nd init
droid x 2nd init roms
droid x second init
how to flash gingerbread roms on droid x
install 2nd init droid x
install 2nd init rom droid x
what is a 2nd init rom
