Tether problem tether
This is a discussion on Tether problem tether within the Gingerbread Development and Hacking forums, part of the Droid X Gingerbread Forum category; Is anyone experiencing problems with the tether patch? I run wireless tether 2.0.7 and it will still bring up the notification on the task bar. ...
Results 1 to 1 of 1
Thread: Tether problem tether
    Points: 5,393, Level: 47
    Level completed: 22%, Points required for next Level: 157
    Overall activity: 0.7%
    chuck54's Avatar
    41016
    697
    Tether problem
    Is anyone experiencing problems with the tether patch? I run wireless tether 2.0.7 and it will still bring up the notification on the task bar. People have said to enable the hotspot, but there isn't a way to do that unless you enable wireless tether. Help?
    I'm diagnosed with a severe case of noobecidis, it might not be treatable...
  1. Wireless Tether Encryption problem
    By Kazdagi in forum Droid X Help
    Last Post: 06-11-2011, 12:56 PM
  2. Barnacle wifi tether-huge problem! Help!
    By Marksman981 in forum Droid X Apps
    Last Post: 04-10-2011, 04:47 PM
  3. Another easy tether problem
    By stormywaters in forum Hacking Help
    Last Post: 04-09-2011, 12:39 AM
  4. Wife Tether Problem!! Loses Connection While On A Call
    By CovsXdRoid in forum Droid X Hacks
    Last Post: 02-14-2011, 07:07 PM
  5. help,problem with wireless tether
    By kiunse in forum Droid X Apps
    Last Post: 08-24-2010, 05:29 PM
captivate gingerbread tethering
captivate gingerbread tethering error
captivate gingerbread tethering problem
captivate gingerbread wifi problem
gingerbread captivate tether error
gingerbread tether error
samsung captivate gingerbread tethering error
tethering error gingerbread
tethering error on captivate
verizon prevent calls while using wireless tether droid x
