Help with Settings.apk
This is a discussion on Help with Settings.apk within the Gingerbread Development and Hacking forums, part of the Droid X Gingerbread Forum category; I am currently looking to find a way to invert the settings menu. All the white bothers me. I have decompiled it and searched the ...
Thread: Help with Settings.apk
    Points: 4,445, Level: 42
    Level completed: 48%, Points required for next Level: 105
    kirbnite's Avatar
    29262
    312
    26 times
    I am currently looking to find a way to invert the settings menu. All the white bothers me. I have decompiled it and searched the pngs, and see none that represent a similar greyish white, so I feel it may not be a png. If it is, anyone know what png or where?
    I know the menu_list.xml has a value for background = #ffffffff, which does match white. I change that to black (#ff000000) and menu_item.xml has an entry for TextAppearanceLarge, which does represent white text. I add inverse to switch to black text.
    After compiling and adding to my phone, I can not find any physical changes. So I edited some of the text in the /values/strings.xml and test again. Now I see a change, but only change were to the text I changed. So no clue what the menu_list and item change. And still at square 1.
    Any one have any input how to theme settings.apk?
    kirbnite's Avatar
    29262
    312
    26 times
    Anyone? I can't be the only one.
    Mooem's Avatar
    1342
    18
    I believe, not quite sure, that those background color pngs for menus (and separators) have to be changed in framework-res.apk. Although I think by doing that you'll end up changing ALL the menus, not just settings. I haven't tried it yet since I'm at work and I don't want to end up bricking my phone without SBF nearby.
    If you find any success with that then please let me know! Also, any tips on how to change the font color to white for black menus would be grand.
    kirbnite's Avatar
    29262
    312
    26 times
    The home screen menu? That text is in framework-res.apk. Part of value/styles.xml
  1. Slideshow Settings
    By crimsonkrystal in forum Droid X Help
    Last Post: 07-01-2011, 12:59 AM
  2. settings/ call settings
    By droiding in forum Droid X ROMs
    Last Post: 01-13-2011, 08:03 PM
  3. Set cpu max and min settings
    By jtdiddy in forum Droid X Apps
    Last Post: 09-01-2010, 09:15 AM
  4. App Settings
    By Steve in forum Droid X Help
    Last Post: 08-10-2010, 04:12 PM
  5. settings
    By Sean Wristen in forum Droid X Help
    Last Post: 08-06-2010, 08:48 PM
edit settings.apk
editing settings.apk
gingerbread edit quick settings
gingerbread settings apk
gingerbread settings.apk
how to invert an apk
setting apk gingerbread
setting background change apk
settings apk gingerbread
white settings apk
