Clean install of Froyo helps eliminate problems
This is a discussion on Clean install of Froyo helps eliminate problems within the Froyo 2.2, News-Rumors-Wishes forums, part of the Droid X General Discussion category; Surprised that I did not see this here (If I missed, my apologies). I did this yesterday and most of my little annoyances have seem ...
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: Clean install of Froyo helps eliminate problems
    Points: 2,657, Level: 31
    Level completed: 38%, Points required for next Level: 93
    Overall activity: 1.7%
    iresq's Avatar
    4885
    250
    Surprised that I did not see this here (If I missed, my apologies). I did this yesterday and most of my little annoyances have seem to be fixed.
    Why a Froyo factory reset really isn't (plus, a fix for upgrade issues) | Android Central
    After the reinstall, I was having some issues with LPP and Beautiful widgets. Today, they appear to have gone away.
    iamtimshady likes this.
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    Interesting link...
    Points: 2,001, Level: 27
    Level completed: 1%, Points required for next Level: 149
    POPdevil's Avatar
    4564
    95
    This is kinda funny this was just posted. Yesterday I did a factory reset and cleared the cache because I was having a few issues. All of my issues cleared up.
    drone46's Avatar
    3600
    Elk Grove, CA
    138
    Prior to 2.2 OTA I was rooted and running Leaked 2.2. To get the 2.2 OTA I unrooted, flashed back to 2.1 and did a factory reset. Then immediately did the OTA update. So essentially I updated from a fresh 2.1 to a fresh 2.2 OTA. The only problems that I have read about that I still had were, the battery usage force close and the missing apps market issue. No text message problems, no lock screen problems, etc. After I got the 2.2 OTA and reinstalled my apps, I rooted and installed Beesley's Build.prop to fix the market issue. Build.prop also seems to have fixed the battery usage force close. Right now I am experiencing no problems that I can detect and am getting 1400 scores on quadrant pretty consistently.
    So my point? I think that there may me some validity to the OP.
    Points: 2,468, Level: 30
    Level completed: 12%, Points required for next Level: 132
    Mudig's Avatar
    9001
    96
    Does a factory reset get rid of all my files and saved settings?
    SwallowTheTime's Avatar
    10634
    44
    I had looked at the post about this technique a couple days ago. I just recently switched to 2.2 two days ago and my main issue is with the music player freezing the phone. The delete data method on the music player works for a day or so, but the problem comes back. It also came back for me right after I added more music. I just did the factory reset technique listed in this thread and it's only been 30 min or so, but the phone is noticeably quicker. The speed is noticeable just switching between homescreens and scrolling through menus for me. Formatting SD card and doing a factory reset weren't a big deal for me because I didn't have a ton of stuff on my phone. You can always backup the files on your SD card to your computer before you format it. I'll let you guys know how it goes in the next few days, so far it looks promising. I read through the entire 15 pages of that thread you linked to, and every person who tried it said it fixed their issues and the phone was quicker so Im hoping for the best.
    iresq's Avatar
    4885
    250
    Quote Originally Posted by Mudig View Post
    Yes. You may be able to backup but I just did 100% clean. Another benefit I have noticed was increased battery life. Better speed, battery, stability = very happy froyo user.
    TheBoyPat's Avatar
    525
    57
    So those of you that did the clean install have no issues with text timestamps OR forced lockscreens w/ pattern?
    10634
    44
    Quote Originally Posted by TheBoyPat View Post
    I'm not sure about the lockscreen because I use just the 'slide to unlock' thing and that's it. As far as the texts goes, I dont have problems with timestamps, but I think they still show up in the wrong order. I've only gotten texts from 2 people since the clean install so Im not sure yet, but I think those two things are actual problems with the software itself and will have to be fixed by a software update. The clean install fixes the freezing and lag issues as well as the other little quirky stuff. For me, I kept getting frozen on the music app. If I turned the screen when in the music player it would freeze the phone and I'd have to pull the battery. So far I'm running much smoother and faster after the clean install. I haven't had any issues with the music player again either. It's only been a day so I will see how it goes over the next few days. However, before I did the install, I would have to pull the battery a couple times a day. If you aren't having any of those problems then you probably don't have to worry about doing this install. As far as I know, the text thing and screen lock will be the same no matter what.
    iresq's Avatar
    4885
    250
    The time stamp issue still exists. I agree with previous poster.
  1. Froyo 2.2 OTA Install Issues...
    By James in forum Droid X Hacks
    Last Post: 10-30-2010, 10:17 PM
  2. How long does it take for froyo to install?
    By emmettsc in forum Droid X Help
    Last Post: 09-23-2010, 09:16 PM
  3. On my Fifth attempt at OTA Froyo... Install Fail.
    By RanballX in forum Droid X Hacks
    Last Post: 09-22-2010, 06:36 PM
  4. Cant install froyo on rooted fone
    By rene in forum Droid X Help
    Last Post: 09-22-2010, 06:29 PM
  5. heres my rom...hope it helps
    By RnD_Solo in forum Droid X ROMs
    Last Post: 09-09-2010, 07:35 PM
Fresh install droid x
Reinstall froyo
Reinstall froyo 2.2
android clean install
clean install droid x
droid x clean install
how to reinstall froyo
reinstall froyo droid x
reinstall froyo on droid x
reload froyo
