I downloaded the .zip file and placed on the root of my dx. However, when I went to install from .zip on SD card it was not there. Plz help
Sent from my ADR6400L using Droid X Forums
This is a discussion on Droid x gingerbread help within the Everything about Gingerbread forums, part of the Gingerbread General Discussion category; I downloaded the .zip file and placed on the root of my dx. However, when I went to install from .zip on SD card it ...
1) are you using bootstrapper? If not, you need to.
2) did you scroll all the way down the list of files to choose from in bootstrapper? The list probably extends past your screen.
Sent from my liberated DX
Need more help? Click above ^
X SBF Instructions
X2 SBF Instructions
.602/.605 Root
.621 Root
Android Dictionary
