problem with SD Card
This is a discussion on problem with SD Card within the Everything about Gingerbread forums, part of the Gingerbread General Discussion category; ok i did a factory reset. my SD Card was fine. a few hours later it's saying " Blank SD Card" ? I hope I ...
Thread: problem with SD Card
    250 Experience Points31 days registered100 Experience Points7 days registered
    Grizzly's Avatar
    31410
    40
    ok i did a factory reset. my SD Card was fine. a few hours later it's saying " Blank SD Card" ? I hope I didn't lose everything on my SD Card. I didn't hit reformat SD Card yet, i've been trying to figure out how to get it to read my SD Card.
    edit: Sd card won't mount. Hmm
    any suggestions? Thanks in advance
    |Droid X|
    bumpin Gingerbread 2.3.3 Rooted
    Previous Phones
    Sidekick - [traded for G1], Rooted G1 - [sold], Rooted Motorola Cliq - [sold], Rooted HTC HD2 - [sold], Rooted Samsung Vibrant - [sold]
    Points: 991, Level: 16
    Level completed: 91%, Points required for next Level: 9
    tani's Avatar
    34686
    Hi there,had same problem,SD card is gone,was told by verizon many had same problem and call Motorolla,did so and wating for replacement Card but you have to return the old one,good luck!
    Points: 1,990, Level: 26
    Level completed: 90%, Points required for next Level: 10
    Xersized's Avatar
    26366
    32
    Grizzley, in your settings look under applications, then developement. If usb debug in checked, uncheck. Then check your sd card. Also if your connected to PC put into charge only mode.
    Mofenrogen's Avatar
    23325
    21
    hi i'm having the same problem. And i'm not so worried about losing my data as much as it bricking my phone. I"m running the latest version of darkslide. does anyonek now if reformatting the card would mess up the phone?
    Xponentially Better
    Guest Xponentially Better's Avatar
    Quote Originally Posted by Mofenrogen View Post
    I formatted my sd one timewhile on a rom and switching to another... Worked fine just lost all my crap. But all the apps and stuff remade the folders. Also you can try it after making a nandroid to be safe.
  1. HELP!! Sd card problem!
    By mapileTree in forum Droid X ROMs
    Last Post: 07-30-2011, 11:47 AM
  2. Problem with SD card.
    By jordanfleming in forum Droid X Help
    Last Post: 02-08-2011, 01:32 PM
  3. Replies: 3
    Last Post: 12-25-2010, 11:17 AM
  4. Problem with media dock and SD card
    By Tony.oe in forum Droid X Help
    Last Post: 09-30-2010, 04:07 PM
  5. Problem with my sd card
    By PorcPuffer in forum Droid X Help
    Last Post: 07-18-2010, 01:21 PM
android blank sd card problem
blank sd card fix
droid x blank sd card error fix
droid x blank sd card fix
droid x gingerbread blank sd
droid x sd card problems
how to fix blank sd card
how to fix blank sd card droid x
how to fix droidx sd card
sd card failure droid x
