How to : Merge Multi-part Movie DVDs and Bluray (Method 1)
This is a discussion on How to : Merge Multi-part Movie DVDs and Bluray (Method 1) within the DVD Catalyst forums, part of the Supporting Vendors category; In a previous article I wrote about the Bluray conversion of Lord of the Rings Fellowship of the Ring Extended Edition from Bluray, http://www.tools4movies.com/2012/03/...-ring-extended , ...
Results 1 to 1 of 1
Thread: How to : Merge Multi-part Movie DVDs and Bluray (Method 1)
    Spotlight Member of the Month
    Points: 7,332, Level: 56
    Level completed: 91%, Points required for next Level: 18
    Overall activity: 9.1%
    Master Tagger
    dvdcatalyst's Avatar
    13895
    331
    20 times
    Post How to : Merge Multi-part Movie DVDs and Bluray (Method 1)
    In a previous article I wrote about the Bluray conversion of Lord of the Rings Fellowship of the Ring Extended Edition from Bluray, http://www.tools4movies.com/2012/03/...-ring-extended, and since the movie was on 2 discs, of course I ended up with 2 files.
    There are a couple of different ways to make this movie (and similar split-movies) into a single video file. In this article I will document the steps for one of them.
    Before we start:
    There is a reason for why movies like this are split over multiple discs. Because of the length of the movie, almost 4 hours in this case, the movie is split over 2 discs to provide you with the best possible quality. While it is possible to put this movie on a single DVD or single Bluray, because these discs can only store so much information, the quality would be lower than that of a 2hour movie. And with this being a so-called high-profile (popular) movie, they wanted to make sure you were getting the best viewing experience they could possibly offer you.
    When you are dealing with a long movie such as Lord of the Rings Extended Edition, or The Stand, Rose Red etc, the file-size is something you have to keep in mind. Devices such as the NOOKcolor/NOOKtablet and Kindle Fire do not like video files that are larger than 2GB. If you are using a device with a memorycard to store your videos on, you will run into similar limitations as well. If you decide to stitch the 2 parts together into a single file, you might end up with a file that can only be played from the internal memory of your device (Xoom/Xyboard/Playbook) or you will have to use something like MP4 Streaming Server to bypass the file-size limitation and stream the movie from your computer.
    When I converted the discs of Lord of the Rings individually, the sum of the file-size for the 2 parts ended up at 4.27GB in size, and this is of course the same for the movie in a single file.
    If you do want to convert the movie to fit within a 2GB filesize, the visual quality will need to be reduced by more than half.
    4.2GB for this movie comes to about 2600Kbps
    to get the almost 4 hour long movie to fit within a 2GB filesize limit, you would have to reduce the video quality to about 1000Kbps
    So how do we join/merge the 2 parts?
    As mentioned, there are a couple of different methods to do this.
    In this article, I will describe the steps on how to do it with DVD Catalyst 4.
    First, convert the 2 parts you want, using the same settings.
    Since I already converted Fellowship of the Ring earlier ( http://www.tools4movies.com/2012/03/...-ring-extended ), I will be using the 2 video files that DVD Catalyst 4 created.
    Start DVD Catalyst 4 using the shortcut on your desktop:
    In order to merge/join the 2 video files from before, 2 settings changes are needed in DVD Catalyst 4.
    In Global Settings > Advanced, enable the "enable join for non-avi" setting (the files I created earlier are MP4's)
    then, since the files have already been converted using DVD Catalyst 4, so there are no black borders, turn off cropping in Global Settings > Borders
    After that, drag your 2 MP4 files onto DVD Catalyst 4:
    Select the top file by clicking on it, then hold down the shift-key on your keyboard and click on the second file.
    If both files have the same settings, you should be able to click on the "Join selection into 1 file" button
    Once you tap on that, DVD Catalyst 4 will add the second listing after the first one. The playlength will match that of both files' playlengths combined.
    Now just start a conversion as normal.
    Since we are using the same settings as what we used to create the individual video files, the quality-loss of a second conversion is nearly non-existent. The conversion will take a little while, but it should be a bit faster than what it was when you first converted them from Bluray.
    (for LOTR The Two Towers and Return of the King, I will be using different methods of joining the multiple parts together, so keep an eye on the news-section on www.tools4movies.com over the next few days.)
    and after the conversion is done, you end up with one large, single-file movie.
    Using this method, the joined version of Lord of the Rings Fellowship of the Ring Extended Edition ended up slightly over 4GB in size.
  1. DVDs to droidx
    By wake4x4ptball in forum Droid X Help
    Last Post: 06-10-2011, 10:48 PM
  2. Transferring dvds to droid
    By redwinger2001 in forum Droid X Audio / Video
    Last Post: 11-08-2010, 07:14 AM
  3. Converting my DVDs to my DROID X
    By movadoevo8 in forum Droid X Audio / Video
    Last Post: 10-01-2010, 10:27 AM
android merge video in one file
convert two video into one on android phone
how do i merge movie clips on droid x
how to combine a video or movies in android
how to combine show parts into one
how to combine videos on android
how to combine videos on droid x
merge 2 videos on android
merge 2 videos on droud phone
merge movie in android
