Droid X and X2 Stock Theming Help
This is a discussion on Droid X and X2 Stock Theming Help within the Droid X2 Themes forums, part of the Droid X2 Hacks category; I have a family of droid X2's and X's and I recently updated them to Android 2.3.5. Now, I've tried CM7 and CM10. CM7 has ...
Thread: Droid X and X2 Stock Theming Help
    Points: 9, Level: 1
    Level completed: 17%, Points required for next Level: 41
    Tagger Second Class
    Erican's Avatar
    67920
    Jan 2014
    Question Droid X and X2 Stock Theming Help
    I have a family of droid X2's and X's and I recently updated them to Android 2.3.5. Now, I've tried CM7 and CM10. CM7 has horrible WiFi issues and CM10 is just too laggy. So I finally just SBF'd to stock after utter frustration with CM7. And yesterday I discovered launchers. Tried out a few different ones and they fixed all my FPS gripes with the stock android and I am very happy with it except for one thing. The status bar/notifications and the menus. Now I looked at UoT kitchen and it seemed to have what I wanted but i'm having trouble using it and not entirely sure how to use it with stock gingerbread. Will it work properly with stock? It asked for ROM's and what not and they didn't have the stock files on hand as far as I could tell so I would have to upload them. I was going for basically exactly what CM7/Stock 4.X looked like in the menus. I could really use some help deciding what to do with this. I'm going to get it working on my X2 and hopefully flash/install it to my other X2's and X's in the family as the stock is horrible. Thanks in advance guys!
    Points: 18,669, Level: 86
    Level completed: 64%, Points required for next Level: 181
    Overall activity: 99.6%
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    Quote Originally Posted by Erican View Post
    there's no 2.3.5 for Droid X (MB810)
    droid x2's (MB870) need to be running 2.3.4, before installing cm7 or cm10
    sorry really have no idea if UoT kitchen will work with the droid X or X2. I recommend Roms Eclipse 2.3 for MB870's and Liquid ICS 2.0 for MB810s
    links in my lists sd_shadow's [Collection] of Links for: Droid X (MB810) and Droid X2 (MB870).
    Points: 9, Level: 1
    Tagger Second Class
    Erican's Avatar
    67920
    Jan 2014
    Thanks for the quick reply! And yeah, I realized about the differences between the X and X2
  1. Liberty theming, how???
    By illegalsmile in forum Droid X ROMs
    Last Post: 06-04-2011, 12:06 AM
  2. New to theming
    By crownedzero in forum Droid X Themes
    Last Post: 01-05-2011, 01:50 AM
  3. Replies: 7
    Last Post: 12-09-2010, 08:59 AM
  4. theming droid x..tragically lost..
    By jigglapuff in forum Hacking Help
    Last Post: 12-03-2010, 10:07 AM
  5. 2.2 OTA Rom Theming Possible?
    By killathrilla in forum Droid X Themes
    Last Post: 12-02-2010, 03:17 PM
