Phone Display Broken and Uncontrolled Overheating in Phone (not battery)
This is a discussion on Phone Display Broken and Uncontrolled Overheating in Phone (not battery) within the Droid X2 Support forums, part of the Droid X2 Forum category; I left my phone in my car for about 2 hours, and it was too hot to touch on the lower left hand portion of ...
Thread: Phone Display Broken and Uncontrolled Overheating in Phone (not battery)
    Points: 577, Level: 11
    Level completed: 54%, Points required for next Level: 23
    TacticalJabr0n's Avatar
    48955
    Oct 2011
    5
    I left my phone in my car for about 2 hours, and it was too hot to touch on the lower left hand portion of the phone. However, the phone still "works", but the only display portion working is the backlight. So I know that I'm getting new messages, and can feel the haptic feedback when I press the place to unlock my phone. But I can't charge it or even turn it on without it burning up again.
    Running CM7 if that makes any difference, and I know there's something called SBFing...but can I even do that if i can't see anything on my phone?
    I'm also leaving for the beach tomorrow so time is a big factor in trying to fix this. Thanks for your advice!
    EDIT: It's not the battery, plugging my phone into the wall with the battery not attached still causes it to overheat.
    Points: 8,909, Level: 63
    Overall activity: 43.1%
    1,340
    79 times
    Quote Originally Posted by TacticalJabr0n View Post
    Honestly sounds like your hardware is burning out, which is a bigger issue you won't be able to do in a day.
    However you can SBF it without having the screen on, just turn it off and boot it into the bootloader. If you've never SBF'd I'd check the thread linked below. Although TBH like I said it sounds like more of a hardware failure which won't be fixed by an SBF. That being said, there is probably no harm in attempting an SBF.
    SBF Info:
    [GUIDE] How to SBF an X2
    48955
    Oct 2011
    5
    Thanks...I've noticed on google that the X2 does have problems with overheating, so do you think it is because of the phone itself or cyanogenmod?
  1. phone won't turn on/overheating battery
    By sirjacktravis in forum Droid X Help
    Last Post: 08-01-2011, 09:11 PM
  2. Some apps won't display after restarting phone
    By dadapearljam in forum Droid X Help
    Last Post: 05-13-2011, 04:44 PM
  3. Replies: 8
    Last Post: 02-15-2011, 04:07 PM
  4. Droid X Phone Broken-Help?
    By Obstinate in forum Droid X General Discussion
    Last Post: 12-25-2010, 11:08 PM
  5. Does Extended Warranty cover broken phone?
    By bullettain in forum Droid X Help
    Last Post: 10-21-2010, 02:10 PM
droid overheating
droid razr overheating
droid x overheating
galaxy nexus overheating
galaxy nexus overheating fix
how to fix an overheated phone
how to fix an overheated phone battery
how to fix overheated phone
phone overheating fix
phone overheating solutions
