I just don't get it. I mean it seems like it dies fast but when I check stats it looks fine
Does that look right to you guys?
Sent from my DROID X2 using Tapatalk
This is a discussion on Battery life seems short but looks right.... within the Droid X2 Support forums, part of the Droid X2 Forum category; I just don't get it. I mean it seems like it dies fast but when I check stats it looks fine Does that look right ...
I have done a lot of write up's....here's a link to some. If you would like help with your phone simply ask, PM me, or drop me an email and I will assist where I can.
List of phones I can help with: Droid, Droid 2, Droid 2 Global, Droid X, Droid X2, Droid 3, Droid Bionic.
If you don't get response here try me on DroidForums, XDA, or Rootzwiki under the same name
You're assuming it's fine in regards to %. It could last 148 hours and your calls could still use 31%. If you're asking if there's anything out of the ordinary there, then no. Almost 16 hours isn't far off of par. If you want it to last longer, you could dim your screen, or use the new hibernate function (when not in use) by holding in the Power Button.
I think 16 hours is good considering i barely get 7-9 out of my stock battery. My extended battery I manage 30+ hours.
Is the battery life on the X2 considerably shorter than the Droid X? I used to be able to get at least 26-28 hrs of moderate usage with the Droid X. With the Droid X2, I'll be lucky if I can get to 20.
Remember the x2 its duel core and higher resolution so that world drain quicker..I get a day and a half on mine with moderate use.
sent from my droidx2 rooted and Gingerbreaded!!!!! With frozen bloatware!!![]()
How to root your phone
How to SBF an X2
How to SBF an X
Guidelines of Conduct
iPhone - You're holding it wrong
My x2 barely makes 7 hours with moderate use. I got the trident case with extended battery and almost got 2 days on the first charge. thats with some phone calls, texting, words with friends, internet/youtube use and such.
