Cyanogen Mod 7 wifi issues
This is a discussion on Cyanogen Mod 7 wifi issues within the Droid X2 ROMS forums, part of the Droid X2 Hacks category; About a week ago I loaded up CM7 to my Droid X2 with the help of GoCliffGo. It's been great except for wifi. It doesn't ...
Results 1 to 10 of 10
Thread: Cyanogen Mod 7 wifi issues
    Points: 1,908, Level: 26
    Level completed: 8%, Points required for next Level: 92
    Pilky's Avatar
    56476
    Mar 2012
    24
    About a week ago I loaded up CM7 to my Droid X2 with the help of GoCliffGo. It's been great except for wifi. It doesn't seem to hold the connection very well and when you do try and connect it, seems to just go into this endless loop trying to reconnect. The only solution is to turn it on and then off again.
    I have it set to never sleep but still no go?
    I'v seen others with the same issue but haven't heard about any fixes.
    Points: 28,222, Level: 98
    Level completed: 88%, Points required for next Level: 128
    7,093
    338 times
    I've heard about this from time to time but I'm unaware of any real "fix" since I never had the problem. It seems to affect some but not others.
    Does your router connect fine with other devices?
    You could also try to reflash the ROM + gapps (with no wipes) in case it was a problem with the installation.
    Sent from my XT926 using Xparent Cyan Tapatalk 2
    Pilky's Avatar
    56476
    Mar 2012
    24
    It worked great before switching to cm7. The only other wireless device I use is my laptop and that works fine as well.
    Pilky's Avatar
    56476
    Mar 2012
    24
    I'm on my phone now but I'll post the thread I seen with people having the same issue when I get on my PC
    Pilky's Avatar
    56476
    Mar 2012
    24
    This is only one of the threads I found but it shows people having the same issue.
    http://www.google.com/url?sa=t&sourc...BU25vTleeED__g
    No sense in reading it really, I was just curious if there was a known fix for it or not. Unfortunately wifi is something I use a lot so I might be going back to stock
    7,093
    338 times
    Could try a clean re-flash or if you're willing to go to 2.3.5 Eclipse is solid.
    Pilky's Avatar
    56476
    Mar 2012
    24
    I'm gonna try a re flash and see what happens. Wipe cache and everything else as well, right?
    7,093
    338 times
    I would wipe everything to start completely fresh. That being said you can also just wipe cache and dalvik then reflash the ROM and GApps.
    Points: 1,922, Level: 26
    Level completed: 22%, Points required for next Level: 78
    wtrp102's Avatar
    53697
    Dec 2011
    11
    Pilky
    Did you solve your wi-fi issue? If so - how?
    Pilky's Avatar
    56476
    Mar 2012
    24
    Unfortunately I solved it sbfing back to stock and using Titanium Backup to remove all the bloat.
    CM7 was great but I need wifi. The fact that it wouldn't hold a wifi connection/take forever to connect was enough for me to go back to stock.
    I may give Eclipse a shot if I'm feeling bored one of these days but for now its stock de-bloated.
    Good luck
  1. Wifi Issues
    By kaiden32 in forum Droid X Help
    Last Post: 12-29-2012, 10:24 PM
  2. Need help with WIFI issues
    By Sphinx8751 in forum Cyanogenmod
    Last Post: 07-28-2011, 10:04 PM
  3. Wifi Issues
    By Konceptz804 in forum Gingerbread General Discussion
    Last Post: 06-23-2011, 12:29 PM
  4. WiFi Issues
    By ChadB in forum Droid X Help
    Last Post: 11-22-2010, 11:47 PM
  5. Wifi issues
    By in forum Droid X ROMs
    Last Post: 12-31-1969, 07:00 PM
cm7 droid x2 wifi fix
cm7 x2 wifi
cyanogenmod 7 droid x2 wifi
cyanogenmod 7 wifi
cyanogenmod 7 wifi fix
cyanogenmod 7 wifi not working
cyanogenmod wifi
cyanogenmod wifi not working
droid x wifi fix
wifi not working with cynogenmod toshiba thrive
