[ROM] [JB] CyanogenMod 10
This is a discussion on [ROM] [JB] CyanogenMod 10 within the Droid X2 ROMS forums, part of the Droid X2 Hacks category; dragonzkiller presents: CyanogenMod 10.0.0-RC0 For the Droid X2 An Android 4.1.2 Jellybean Experience Features: Pop-up Text Message Notifications Lockscreen Customization Status Bar/Pulldown Customization Homescreen/Drawer Customization ...
Page 1 of 49 12311 ... LastLast
Results 1 to 10 of 485
Like Tree38Likes
Thread: [ROM] [JB] CyanogenMod 10
    Points: 28,483, Level: 99
    Level completed: 9%, Points required for next Level: 1,517
    Overall activity: 37.7%
    7,093
    338 times
    Features:
    • Pop-up Text Message Notifications
    • Lockscreen Customization
    • Status Bar/Pulldown Customization
    • Homescreen/Drawer Customization
    • Themes
    • Profiles
    • Hard Button Key Remapping
    • Quiet Hours
    • And ALL the Jellybean Featues: Google Now, Smarter Keyboard, Notifications Overhaul, and much much more!
    Working:
    • WiFi
    • Bluetooth (see known issues)
    • 3G
    • Calling
    • GPS
    • Google Now
    • Audio System! (This was the biggest thing keeping me from releasing CM10.)
    • Camera..... ish (See known issues)
    • Maps (You won't end up in a lake in Norway on your trip to the movie theater)
    New to Alpha 3:
    • Not much: that's about it. Few added features that were added from October until January, but not much has really changed.
    • Wifi: Should be fixed from A2.9
    • Minor CM Enhancements.
    Known Issues:
    • Recovery: Recovery has been fixed since Alpha 2, but flashing ROMs doesn't work. Restoring nandroids will work fine however.
    • Bluesleep/Deep Sleep: at it's current state, Alpha 2 doesn't have the bluesleep fix in it. This is because when it is enabled the proximity sensor doesn't turn the screen back on when it's supposed to also causing the phone call to kill audio. This problem can also occur by toggling bluetooth ("fixing the bluesleep"). The only known work around is to press the home button and swipe your finger across the sensor. Thanks to 32BitWhore for the help.
    • Stability: While not exactly an issue as CM10 is INCREDIBLY more stable than CM9, that doesn't mean that it's 100% yet. As of now, I've only had the broswer crash twice and the notification drawer flicker once. Your milage will vary.
    • Camera: At it's current state, the camcorder will not work like in CM9. I can't really do much about that for the moment or at all.
    • Some ICS/JB Apps Will Crash: This is noticeable on Chrome for example. This is because our drivers don't have External OES Textures. Basically that means when the apps want to draw using them (such as with Chrome's tab preview) the app will crash. This is the same problem on CM9/ICS. There is nothing we can do.
    • Data usage: Just don't ask me. I might get to it again one day. We'll see.
    Installation:
    This can be installed over CM7/CM9 or BLUR but you MUST wipe data and cache if from CM7/BLUR. (CM9 should work w/o wipe, but it's untested).
    1. READ THE ENTIRE POST
    2. Download the links provided below and put it on the External SD Card
    3. Install the BSR (patched if on an AOSP based ROM, unpatched if on BLUR)
    4. Reboot into the BSR
    5. NANDROID
    6. Install the CM10 zip from the SD Card
    7. Install the GAPPS from the SD Card
    8. MILESTONE X2 USERS ONLY: Install the WiFi patch from the SD Card
    9. Wipe both DATA and CACHE if coming from BLUR or CM7 (no need to wipe Dalvik if you wipe both of these)
    10. Reboot your phone
    11. Enjoy a better phone experience
    Instructions for BSR Recovery
    -You need to use the hijack-boot.zip from alpha one before you install the cm7 patched BSR in order for it to work. Instructions for that can be found here
    http://forum.xda-developers.com/show...postcount=1519
    Downloads:
    Also, if you would like (but not needed) to donate, see the donate button by my name. Gas/food money goes a long way
    I am not responsible for what you do to your phone. Flash at your own risk.
    REQUIRED Google Apps (GAPPS):
    http://wiki.cyanogenmod.org/w/Gapps . Download the latest Jellybean version (for 4.1.x) of them for here and check the MD5 sums from there also.
    MUST SBF IF COMING FROM A1.
    CyanogenMod 10-20130113-Daytona Alpha 3: http://d-h.st/82g
    Milestone X2 WiFi Patch (for all versions of 10): http://d-h.st/Pdy
    Changelog:
    Alpha 3:
    New CM10 Features added since October
    Alpha 2.999999999999:
    Update to 4.1.2
    Fix rebooting problem with SD Card apps
    Fixed internal/external swapping
    Performance updates via libc enhancements
    Some others, it's been a while
    CyanogenMod 10-20121028-Daytona Alpha 2.99999999: http://d-h.st/QcA
    Alpha 2:
    Fix SD Card apps
    Fixed camera app
    Added Advanced Settings (only HWA working)
    New WIFI Module (DX2 only)
    mediaserver (apparently) fixed
    CyanogenMod 10-20121007-Daytona Alpha 2: http://d-h.st/9J6
    Alpha 1:
    First Public Release
    Download: CyanogenMod 10-20120928-Daytona Alpha1: http://d-h.st/7y5
    ** DXF is not responsible for what you do with your device **
    Edit:
    17 March 2014 by sd_shadow - fixed gapps link
    07 Feb 2015 by sd_shadow - fixed gapps link again
    7,093
    338 times
    A couple of notes.
    - You must be on 2.3.4 to flash the Rom
    - If you are already on Alpha 1 you must SBF to stock 2.3.4 before you flash Alpha 2 (Nandroiding back to CM9 or any ICS ROM first then updating to A2 has been confirmed to work... There can always be complications when doing it this way though, so be careful.)
    Points: 22,755, Level: 93
    BHuber09's Avatar
    34670
    Atlantis
    6,636
    446 times
    Wow.. I never thought his would have happened. You X2 users are luckyyyy. JB is the smoothest thing ever.
    I'd be all over this if I had an X2.
    GoCliffGo05 and victimssun like this.
    FreeMyMoto!!!
    If you need help PM me!!!
    7,093
    338 times
    Quote Originally Posted by BHuber09 View Post
    ^Truth! he claims it is even more stable than our ICS release (aside from the unavoidable issues.) So excited, everyone with an X2 should flash this at least once without question.
    Points: 45,910, Level: 100
    DirtyDroid's Avatar
    28665
    Upstate,NY
    14,576
    384 times
    stuck.. get your jelly bean on x2 users
    tap'd from the Gnex
    BHuber09's Avatar
    34670
    Atlantis
    6,636
    446 times
    Flash it once and they will be good!! No reason to flash again besides updates hahah
    GoCliffGo05 likes this.
    FreeMyMoto!!!
    Points: 29,424, Level: 99
    Nemo aeternamn's Avatar
    37333
    Mo-ab
    7,738
    165 times
    This is awesome.. the x2 is still alive! Looks like u need to put this on my friends phone!
    Cellar Door
    "Who are you people and where is my horse?"
    Post Script:
    Nemo Aeternamn Wallpapers
    Super Mod Team Lead
    Points: 23,961, Level: 94
    Level completed: 62%, Points required for next Level: 389
    Overall activity: 44.1%
    jwalz's Avatar
    34326
    7,603
    296 times
    Who is gonna port to the X haha ... this is sweet cliff hope you enjoy it bro
    tap'n 2.4
    37333
    Mo-ab
    7,738
    165 times
    just pulled up on my computer... wow... now that's a pattern for your lock screen!!!haha
    Post Script:
    7,093
    338 times
    Lol thanks. My computer decided it didn't want to let me SBF with RSD Lite until about the 5th go around. So i'm just now getting around to installing BSR to throw this bad boy on there.
  1. Cyanogenmod.
    By meskes in forum Droid X2 General Discussion
    Last Post: 03-11-2012, 03:12 AM
  2. about CyanogenMod 9 ICS
    By BAABBAD in forum Droid X Hacks
    Last Post: 02-21-2012, 06:58 AM
  3. Cyanogenmod?
    By nathey6 in forum Droid X General Discussion
    Last Post: 01-28-2012, 01:20 AM
  4. cyanogenmod?
    By The Thrill in forum Droid X ROMs
    Last Post: 08-01-2011, 02:40 AM
  5. need help after cyanogenmod
    By cw0974 in forum Hacking Help
    Last Post: 07-24-2011, 01:16 PM
cm-10-20130113-unofficial download
cm10 alpha 3 droid x2
cm10 alpha 3 droid x2 download
cyanogenmod 10 droid x2
cyanogenmod 10-20130113-daytona alpha 3
cyanogenmod 10.0.0-rc0 for the droid x2
cyanogenmod for droid x2
droid x cyanogenmod
droid x2 cyanogenmod
droid x2 roms
