[ROM] [JB] CyanogenMod 10
This is a discussion on [ROM] [JB] CyanogenMod 10 within the Droid X2 ROMS forums, part of the Droid X2 Hacks category; Kind of a noob here when it comes to CM. I have been running Eclipse for over a year now and I've gotten pretty good ...
Page 3 of 49 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 485
Like Tree38Likes
Thread: [ROM] [JB] CyanogenMod 10
  1. #21
    Points: 851, Level: 15
    Level completed: 51%, Points required for next Level: 49
    pup154's Avatar
    46537
    Aug 2011
    Kind of a noob here when it comes to CM. I have been running Eclipse for over a year now and I've gotten pretty good at working with the new releases of it. Well, I want to try this CM10. Number 3 of the OP says "Install the BSR (patched if on an AOSP based ROM, unpatched if on BLUR)". My question is what which BSR do I use and where do I get it?
    DX2
  3. #22
    Points: 28,413, Level: 99
    Level completed: 4%, Points required for next Level: 1,587
    Overall activity: 18.9%
    7,093
    338 times
    First off if you are on eclipse then you will need to SBF to 2.3.4. Also if you are on eclipse then you should already have the correct BSR, its the same one you used to flash the ROM you are on now.. Here is a link to it again though http://www.markhm1972.com/MotorolaDr...rap_signed.rar
  4. #23
    7,093
    338 times
    Bump!!
    Charge only mode and recovery has now been fixed. See the second post of this thread for a link. Or here http://forum.xda-developers.com/show...&postcount=188
  5. #24
    Points: 22,755, Level: 93
    BHuber09's Avatar
    34670
    Atlantis
    6,636
    446 times
    X2 users! Where y'all at?!?
    FreeMyMoto!!!
    If you need help PM me!!!
  6. #25
    7,093
    338 times
    I'm on it again now. System recovery is flawless. Plus if you have titanium backup you don't have to worry about not being able to download your old apps. You can just restore them.
    Sent from my MB870 using Droid X Forums
  7. #26
    Points: 272, Level: 5
    Level completed: 44%, Points required for next Level: 28
    Romans's Avatar
    60617
    Jul 2012
    5
    DX2 user here, I installed the ROM according to the directions. I updated from CM7. I keep getting an error when trying to click the android guy to set up the phone. It says "unfortunately, setup wizard has stopped".
    EDIT:
    I found a way to bypass the wizard, and CM10 seems to be great, however it seems to reboot when I try to access the backup option in the settings app. Also, the play store crashed a few times.
  8. #27
    pup154's Avatar
    46537
    Aug 2011
    Thanks!
    DX2
  9. #28
    7,093
    338 times
    Did you figure it out? I'm not getting any crashes at all. You have to be on 2.3.4 and you have to install the ROM before the gapps or you will get force closes like that. I haven't used the backup option on the phone just titanium backup. Just to note the ROM comes with ROM manager but don't use it. Its just a CM thing but doesn't play nicely with our device. Were you able to get charge mode and CM7 recovery working?
  10. #29
    Hi, there! I just upgraded from CM7, and I had a few questions:
    1- What does this wifi patch actually do, and is it safe to simply install it from my BSR after I've already set up CM10, or will this cause problems? (Do I have to re-flash the rom?)
    2- Is Alpha 2 available? I see it mentioned and referenced in the OP, but the download link still says Alpha1.
    3- Who is Dragonzkilla, and how can I thank him?
  11. #30
    7,093
    338 times
    WiFi patch is only for milestone users. If you need it just flash it after gapps along with the ROM. If you are already on the ROM and need it flash it in recovery.
    Alpha two is not available yet but the alpha one does not come with charging mode or recovery so you need to install it manually using the instructions in the op or the second post link.
  1. Cyanogenmod.
    By meskes in forum Droid X2 General Discussion
    Last Post: 03-11-2012, 03:12 AM
  2. about CyanogenMod 9 ICS
    By BAABBAD in forum Droid X Hacks
    Last Post: 02-21-2012, 06:58 AM
  3. Cyanogenmod?
    By nathey6 in forum Droid X General Discussion
    Last Post: 01-28-2012, 01:20 AM
  4. cyanogenmod?
    By The Thrill in forum Droid X ROMs
    Last Post: 08-01-2011, 02:40 AM
  5. need help after cyanogenmod
    By cw0974 in forum Hacking Help
    Last Post: 07-24-2011, 01:16 PM
cm-10-20130113-unofficial download
cm10 alpha 3 droid x2
cm10 alpha 3 droid x2 download
cyanogenmod 10 droid x2
cyanogenmod 10-20130113-daytona alpha 3
cyanogenmod 10.0.0-rc0 for the droid x2
cyanogenmod for droid x2
droid x cyanogenmod
droid x2 cyanogenmod
droid x2 roms
