[ROM][BETA][ICS]CyanogenMod 9.0.0 RC1 BETA1[UPDATED 8/13]
This is a discussion on [ROM][BETA][ICS]CyanogenMod 9.0.0 RC1 BETA1[UPDATED 8/13] within the Droid X2 ROMS forums, part of the Droid X2 Hacks category; DRAGONZKILLER PROUDLY PRESENTS: CyanogenMod 9.0.0-DROIDX2-BETA1 UPGRADING FROM ALPHA 4 OR LOWER REQUIRES A DATA WIPE!!! Features: For a list of features added to ICS please ...
Results 1 to 10 of 14
Thread: [ROM][BETA][ICS]CyanogenMod 9.0.0 RC1 BETA1[UPDATED 8/13]
    Points: 27,254, Level: 97
    Level completed: 91%, Points required for next Level: 96
    Overall activity: 29.9%
    7,093
    338 times
    Features:
    For a list of features added to ICS please go to the Android website: Android - Introducing Ice Cream Sandwich
    Also any of the CyanogenMod features you know and love from CM7 are in here too plus a few extras
    Also, as this is beta, pretty much everything is working but a few things are not. The stability of the ROM is so-so at times. Unfortunately I can't do much about it.
    Working:
    • MMS is working!
    • Added dock settings (not sure if it works yet)
    • Added Mashup to build by default (thanks to Balltounge for the props)
    • Camera (see known issues for details)
    • Data Usage (optional for ALPHA 4 ONLY, not on by default, see section below)
    • WIFI **NEW FOR MX2!!! SEE PATCH BELOW***
    • Bluetooth
    • Data/3G
    • Tethering (see known issues)
    • HQ and LQ Youtube (used to be a problem)
    • And a lot of little things
    Known Issues:
    Besides a whole lot more of a lot of little things:
    • Graphics memory sometimes runs out: as we are on less RAM the memory management is a bit whack. Sometimes while rotating an app (noticeably the browser) it will "twitch" and crash. Also systemserver (the main background service) will crash and Android will restart (rarely).
    • Chrome beta doesn't work: it also requires kernel mods which I haven't messed with yet.
    • NOTE ABOUT CAMERA: Camera works where as camcorder doesn't. All of the features of the camera section work though.
    • ***Videcam Illusion has been working on other CM9 based Roms. Give it a try for recording.
    • USB Tethering doesn't work: This is an issue on all MotoTegra devices right now I believe.
    Installation:
    This can be installed over CM7/CM9 or BLUR but you MUST wipe data and cache if on a build of CM9 before Alpha 5. Also do NOT (I repeat) do NOT use TiBu to backup data from CM7/BLUR. I don't want to hear about how that doesn't work.
    1. READ THE ENTIRE POST
    2. Download the links provided below
    3. Install the BSR (patched if on CM7/CM9)
    4. Reboot into the BSR
    5. NANDROID <--- you'll probably want to go back to this
    6. Install the CM9 zip from the SD Card MX2 Users Go to the MX2 Thread for the Patched CM9 zip once it has been updated to Beta 1
    7. MX2 ONLY! Install the WiFi Driver zip from the SD Card
    8. Install the GAPPS from the SD Card
    9. Wipe both DATA and CACHE (no need to wipe Dalvik if you wipe both of these)
    10. Reboot your phone
    11. Enjoy CM9 Beta 1
    Data Usage:
    Data usage works with Alpha 4 to some extent. It will start to monitor your data usage through your 3G radio. What it doesn't do yet is monitor WiFi usage, allow you to reset your usage, track which apps are using data, and allow data warnings/cutoffs. Seems like a lot that doesn't work, but baby steps. A problem however occurs whenever Android crashes. If it does, the boot logo will show and eventually will completely crash the phone and restart. This is an issue with the kernel mods causing a panic when already installed and trying to get a 3G connection. As of now I don't know how to fix this and as such I'm having the download separate.
    This requires adb or root explorer to use and needs to overwrite the file of the same name in /system/etc.
    Downloads:
    Also, if you would like (but not needed) to donate, see the donate button by my name. Gas/food money goes a long way
    REQUIRED (even if updating) Google Apps (GAPPS): Goo.im Downloads - Browsing gapps. Download the latest version of them for here and check the MD5 sums from there also.
    WIPE DATA/CACHE IF UPDATING FROM ALPHA 4 OR LOWER!
    CyanogenMod 9-20120814-Daytona Beta1: Dev-Host - cm-9-20120814-UNOFFICIAL-daytona.zip - The Ultimate Free File Hosting / File Sharing Service
    As before with Alpha 5, Beta 1 is still mostly stable, but will benefit greatly with the use of V6 Supercharger.
    Milestone X2 WiFi Patch (for all versions of CM9): Dev-Host - MX2_CM9_WIFI.zip - The Ultimate Free File Hosting / File Sharing Service
    Old Downloads:
    CyanogenMod 9-210120716-Daytona Alpha 5: Dev-Host - cm-9-20120716-UNOFFICIAL-daytona.zip - The Ultimate Free File Hosting / File Sharing Service
    CyanogenMod 9-20120613-Daytona Alpha 4: Dev-Host - cm-9-20120613-UNOFFICIAL-daytona.zip - The Ultimate Free File Hosting / File Sharing Service
    Alpha 4 Data Usage (NOT A BSR PATCH, SEE ABOVE): Dev-Host - hijack-boot.zip - The Ultimate Free File Hosting / File Sharing Service
    CyanogenMod 9.0.0 RC0 Daytona Alpha 3: update-cm-9.0.0-RC0-daytona-Alpha3-signed.zip
    MD5 sum: ce776352f481c8be67296ac3e09abe77
    Changelog:
    Beta 1:
    Updated to "stable" release of CM9 (though we're not 100% stable yet)
    CM9 Features/Translations updated
    Alpha 5:
    WAY more stable than Alpha 4
    MMS fixed
    Mashup added by default
    Dock settings added
    Removed dual USB notifications
    SD Card Apps (should) work now (tested with Temple Run)
    Few little things
    Alpha 4:
    Camera
    Data usage
    More CM9 features (themes, lockscreen enhancements, music app)
    Alpha 3 (first public release):
    Minor stability update
    Few CM9 features added
    Alpha 2:
    More stability/features
    Graphics capabilities updated
    Added pictures to MMS.apk's notifications (now officially in CM9, AOKP, and Codenamed: Android) Yay me!
    Alpha 1:
    First boot into ICS/CM9
    Originally posted by DZK (obviously) All credit goes to him.
    Disclaimer... I nor dxf are responsible for what you do to your device..
    Points: 45,910, Level: 100
    DirtyDroid's Avatar
    28665
    Upstate,NY
    14,576
    384 times
    Wheres all the X2 peeps at? :/
    Quote Originally Posted by DirtyDroid View Post
    no kidding! the droidX was way more successful in the custom dev community. it has software right now that makes it so fast it feels like a dual core phone.
    i dont think there is any real good roms for the dx2! eclipse seems the best, but i dont think its anywhere near as polished as some droid X roms.
    really sad, and i doubt it will get better because everyone wants 4g phones now. i just have my dx2 in wifi mode and i use it as a small tablet and sip phone!
    im trying cm9 right now. please let it be good... pleaseeee
    7,093
    338 times
    If you want a good ICS experience on the X2 I would recommend Paranoid Android. It's built from Cm9 beta but with 'tablet' like features. It will have the same bugs however.
    All I can say about the future of the DX2 rom scene is that kexec is being worked on, so all hope is not lost... Yet.
    well maybe im stuck with eclipse?
    wiped all data and everything, flashed and booted into bootstrap recovery and i tried to flash cm9. immediate error about the kernel check being wrong.
    then i tried paranoid android and the same thing.
    am i using the wrong bootstrap? im using the one in the eclipse thread
    7,093
    338 times
    Did you sbf to 2.3.4? Eclipse is the only rom for us that will work on 2.3.5.
    i have not! i will do that. thank you so much
    7,093
    338 times
    No problem! Also about your BSR question. You use the normal one once you are on 2.3.4 to install CM9. Once the rom is installed you'll need to install the patched BSR.
    its alive! works great!
    thanks again!
  1. [ROM]CyanogenMod 7.2.0-RC1 X2 [BETA]
    By Nemo aeternamn in forum Droid X2 ROMS
    Last Post: 12-11-2013, 10:59 PM
  2. CyanogenMod 9 [Beta]
    By cory46 in forum CM9
    Last Post: 12-06-2012, 10:06 PM
  3. [ROM] MIUI4DX2 Beta1 [BETA]
    By victimssun in forum Droid X2 ROMS
    Last Post: 05-18-2012, 04:00 AM
  4. CyanogenMod 9 [Beta]
    By cory46 in forum Ice Cream Sandwich ROMs
    Last Post: 05-10-2012, 02:00 PM
  5. [ROM] CyanogenMod 7 for DX [BETA]
    By Droid-Xer in forum Cyanogenmod
    Last Post: 10-28-2011, 10:05 PM
cm9 beta droid x2
cyanogenmod 9 droid x2
cyanogenmod 9 droid x2 download
cyanogenmod-9-20120716-unofficial-sholest-20120716-signed
download cm 9 beta 2 droid x2
droid x2 cyanogenmod 9
droid x2 ics rom
droid x2 ics rom rom
droid x2 patched bsr
rom sholest
