Twitish Proudly Presents...
MIUI v. 2.8.10 Beta
Sorry Screenshots are so small, still trying to learn the best way to post all these pictures.
Includes:Known Issues:
- Latest Changes in the MIUI Rom (Updated to 2.8.10!)
- Updated to CM9 Beta!!
- MMS Fully works!!!
- Everything that works in CM9 Beta should work here.
- Likewise everything that is broken in our CM9 Beta is broken here.
- Themes work!
- Camera works!!!
- Added in init.d Scripts
To Install:
- No Data Usage Monitor.
- No Camcorder. (Use the Video Illusions App to gain this back!)
- Browser Crashes during a Rotation.
- MIUI Home Launcher likes to use A LOT of memory, can become unstable if you love apps. Try using Apex or another ICS Launcher.
- Occasionally it will reboot randomly.
- Google TTS is broken.
YOU MUST USE Dragonzkiller's patched BSR once you are on this ROM.
- You must be on 2.3.4
- Boot into BSR (Obviously)
- YOU MUST WIPE DATA AND CACHE!!!
- Clear Dalvik Cache.
- Install the MIUI-2.xx.zip from BSR.
- Install the Latest Gapps.
- Reboot Phone.
- Profit.
MIUI is a great Chinese rom that is then translated by the folk over at MIUI.us. I then take what was built for the Atrix and port it over to our phone. However, the 2.8.10 is the last build that will be made for the Atrix, therefore this is probably going to be the most stable build we have from here on out. I am still going to port MIUI, however it may take me longer and will be less stable. College is starting and I will have less time, but I am going to do what I can.
Included in this are some init.d Scripts that run automatically at boot! Here is a rundown of what each of them do:
91Remount: Remounts System, Cache and Data using better mount flags to reduce Latency and make sure it only writes when it needs to.
92SDCard: Increases default read/write value of the SD Card to 2048 from 128
93WifiDrop: The system will turn off WiFi after 15 minutes of inactivity (WiFi Drains less battery, so 15 minutes is acceptable) This changes that value from 15 minutes to 1 minute. The only issue is that now Android will have to reconnect to WiFi more, but the fact that it's so fast to reconnect will make this unnoticeable. This will allow the system to go into Deep Sleep faster (assuming there's nothing pinging the WiFi). Note: Due to the way MIUI is set-up, this will only work if you freeze CloudServices.apk, XiaomiApplicationFramework.apk and MIUI.usForums.apk as those ping constantly causing WiFi to never drop.
94Vacuum: Cleans all SQLite Databases on Boot.
95ZipAlign: ZipAligns all apks found on the system.
96sysctl: Throws in some sysctl tweaks defined in /system/etc/sysctl.conf
Downloads:
MIUI v. 2.8.10 http://dl.dropbox.com/u/94438244/MIUI-2.8.10-3.zip
Latest MIUI GApps http://dl.dropbox.com/u/94438244/MIU...s-08232012.zip
Bluesleep Fix: http://dl.dropbox.com/u/94438244/bluesleepfix.zip
What is the Bluesleep fix?
The Bluesleep fix was a bug in the system that prevented it from going into Deep Sleep. Simply flash (No need to wipe anything) and your phone will be able to Deep Sleep again. Credit goes to Th3Bill for this fix.
NOTE:You may need to move the init.d scripts to get back into BSR!!!
FAQ:
Q: So, what exactly is this?
A: This is MIUI!
Q: I don't like to download from Dropbox, is there another mirror?
A: Unfortunately, no. Dropbox is all I have. If someone would like to mirror it, please say so.
Q: When will this be updated?
A: Whenever I get a stable enough build out.
Q: I have a bug/issue...
A: Please feel free to post it here!
Q: OMFG! UR SO DUMB! I HATE U AND MIUI!
A: Then go somewhere else.Let's try to keep this thread clean.
Q: OMG!! YOU'RE THE BEST!!! LET ME DONATE!!!
A: First, please donate to Dragonzkiller for his CM9 port. If you're still inclined to do donate for me, please click on the left.
Disclaimer;
I GoCliffGo05 or DroidXforums take no credit for anything posted above and WE are not responsible for what you do to your device. I just wanted to share this with the DXForums. Enjoy, and thanks Twitish.
5Likes
